Jaybird
Yosemite, CA & Desert Hot Springs, CA
ok EXPERTS.......
HAVE A SET OF MICHELIN'S (6)
LT235/85/R16
How do I explain this?
Should be a total of 20,000 miles on the tires ( 2 years)
at 10K full new set under warranty for ALL SIDE WALL CRACKS
NOW at 20,000 miles ( another 10) and ONE YEAR later
ANOTHER NEW SET UNDER WARRANTY all side wall cracks
am I just getting bad product, or am I doing something wrong
80# PRESSURE in all tires
jb
Chuck&Gail
In the Colorado Mountains
Do you use tire covers when stored? IMO they help a lot.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
rchonly
Kingman, Arizona, USA
Sounds like Michelin has a quality control problem.
Even living here in the high heat of the desert I've never had a tire get sidewall cracks in the the first year and I've never owned a set of tire covers.
Roger
1995 Alpenlite - St Andrews 33RK
2001 Dodge CTD-2500 Quad Cab,4x4,AT,LngBed,w/B&W-GN & Companion
teb1272
Memphis
I suspect you are the victim of high ozone concentrations, lots of ultraviolet radiation, and high temperatures. Are you parked near large electrical transformers or motors? They generate ozone, which is the worst enemy of tires. You might be able to solve your problem by driving the MH 10+ miles each week to be sure the antiozonants have a chance to migrate to the surface frequently. Tire cover may, or may not, help-they protect from uv, but really don't do anything for ozone.
Gale Hawkins
Murray, KY
Is not this a current known issue with some lines of Michelin?
othertonka
Stockton, CA
What were/are the date codes on the tires? Could they have been old to begin with? Tire covers do protect from the sunlight along with frequent driving to exercise the tires and bring up the chemicals that are supposed to prevent this, whatever they are called, not a chemist so I don't know the name, just know they are in there.
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
byronlj
Loveland, CO/Lake Havasu City, AZ
I have two friends that just had Michelins replaced under warranty after just one year. One set had 13k the other 60k. The dealer that replaced them didn't seem surprised. I don't believe it is from just sitting in the sun.
Dave
byronlj
07.5 Silverado LTZ Ex. Cab 3500HD dually 4X4 duramax LMM/allison 6spd
07 HR Presidential Suite 37RLQ
Jaybird
Thanks to all replies,
I do drive the coach each week, just to run to the grocery store or into twon.
It gets about 25 or 30 miles a week.....
No transformers, or motors, just telephone poles.
Puzzlement.
rvdriverca
B.C. Canada
Check the date of mfg. Than do what I did see what brand of tires UPS uses. They have the money to do research, you and I don't have. BTW they use Goodyear.
Deen
Vancouver, WA
Gale Hawkins wrote: Is not this a current known issue with some lines of Michelin? Our 275/70 22.5's are 6 years old and I just noticed a little cracking in the sidewalls right at the tread line.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
