Betsy II
BC
Our 5er has a Parallax converter, model 7445. I've been doing some research on these units to see how effective they are at charging the batteries in the 5er.
We have 2 Interstate U2400's in the 5er. I have found the onboard converter/charger is not that effective at topping up the charge to 100%, best I've achieved is 90%. Charge state determined by measuring the specific gravity of each cell.
I now understand there are 3 - 4 stages of charging to properly charge these batteries from a 80% DOD to fully charged. The onboard charger does not have this capability and therefore cannot propely charge the batteries.
I came across an article about a conversion from a Parallax unit to a Xantrex unit that has 3 stages of charge that will properly charge the batteries.
Does anyone have any experience with installation of a multi-stage charger that does the job?
Thanks in advance for your comments.
Roy
RPFAN
Poughkeepsie NY
Converter install is easy. 1st and most important is to make sure the unit has plenty of ventilation. Other than that, converter is one AC plug and 3 wires. One 12 volt DC hot. One 12 volt DC ground and one copper chassis ground. Done.
Rich
Rich, Fern, Bethany, Justin. 2005 Ford F450,Lariat, 6.0 PSD,CC,DWR,4WD, Air Hitch, 100 Gallon Aux fuel tank.
2009 Cardinal 3802BH 5 slide, on order!
Our "Condo in the Woods"
Leave no roller coaster unridden!
ryoung
Indiana
I have a Progressive Dynamics converter with an optional charge wizard that senses the battery's conditions. Wiring it shouldn't be any different in the unit you presently have.
Go here for a description. Progressive Dynamics
ryoung
VintageRacer
Dundas, Ontario
I did the Xantrex conversion, worked out fine for me.
Brian
2003 Dodge Ram 2500 Quad Cab, Hemi, 5 speed manual, 3.73 gears, Tow Beast hitch with 24" extension.
28 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
2004 Travel Hawk 8' Truck Camper - Roll at 16K combined weight
Betsy II
BC
To: ryoung...
I have a few questions about your system.
Which model of PD converter do you have?
Was this a conversion you did yourself or original unit?
Does it have a 3 or 4 stage charge capability for, say, a battery that has been discharged to 10- 20% charge level?
Any other comments would be appreciated, perhaps through a personal message.
thanks,
Roy
Betsy II
BC
To: VintageRacer...
Which model of Xantrex converter do you have?
Did you do the conversion yourself?
thanks,
Roy
JSowders1
Emery SD
I solved your problem with 150 watts of solar and digital controller. I haven't heard my charger come on in months and batteries are 100% all the time, 13.6 volts. Batteries are u2000, 2 ea.
2000 1T Ford PSD SC Dually 2WD
2005 Grand Junction 35TMS
Mor-Ryde Suspension & Pinbox
Movin View
Beagle-Maggie
Lifetime GoodSam Member
smkettner
Parallax to Xantrex upgrade
With two batteries the XADC40 would be plenty IMO. If you are in a super big hurry to get max charge in the battery get the XADC60.
Johnofbham
Birmingham, Alabama
A temperature probe helps also for proper charging.
