RV.Net Open Roads Forum: Fifth-Wheels: wiring x-tra trailer plug for back of 5vr
 > wiring x-tra trailer plug for back of 5vr
jsmtam90
Vicksburg,Michigan
Posted: 05/29/08 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
just curious how others have wired an x-tra trailer plug for a pull behind with your 5vr...I have a Gm truck and really don't want a lot of ugly splices to mess up the factory wiring. Thinking of making some type of pig tail to come out of the 7 pin plug....please give me some ideas...thanks.
Martyn
Bennett, Colorado, USA
Posted: 05/29/08 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I spliced into the trailer harness about 2 feet from the rear of the trailer. As I have a sealed underbelly on the trailer I took of the covering panel and then ran all the wires to a 4 wire outlet that I screwed to the rear bumper with parts I got from Checker Auto. When the panel was replaced it was all hidden. (I'll look for links to the parts later, if I get some time)
If you make a pigtail from the front connector you will have a lot od additional wiring. I didn't fancy that
2004.5 Dodge Ram 2500 QC CTD 4x4 SLT; 2007 Coachmen Chaparral 267RLS;
Reese 15K Slider;Prodigy;JT Stabilizers;2 Honda EU2000i's;
2006 Glastron MX175;
rv-forums
2005 Dodge Magnum for the DW
tnance
Nixon/Texas
Posted: 05/29/08 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
On our Teton there is a junction fuse block inside our basement. Each wire, left & right turn signal-brake, running lights, 12-v, etc have separate fuses before the wires continue on to their loads. I purchased an additional fuse block and wired both fuse blocks in parallel. From the second fuse block I ran #10 stranded to the rear of our fifth wheel.
This way if there is a short in our toads running light circuit the running light circuit for the fifth wheel is not effected and vice versa.
Also the original load on the fifth wheel circuits are not increased as when you just tie into the trailers rear circuit as many do.
2005 Freightliner M2 106 class 7 HDT
2004 Teton Sunrise Grand
Jeep Wrangler toad
...PICTURES...
sandblast
salt lake city utah
Posted: 05/29/08 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
I Went to my local Wildcat dealer to see about a receiver hitch and a flat 4 electrical connect to pull my ATV trailer.
Sure, they said, $550.00 thank you!
They must think they`re Exxon Mobil!
Charlie Q
Brusly, Louisiana
Posted: 05/29/08 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
I had my hitch custom made and the wiring installed for around $350.
My spare is in a recessed area under the rear of my 5er and the wires were in that area.
'03 Chevy CC/SB,D/A,4X4, Airlift Bags, Bilsteins, Reese slider, Hypertech programmer.
'06 Mobile Scout 31 BWFS
Yamaha 3000ISEB
Scarface56
Appleton, Wisconsin
Posted: 05/29/08 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
They make an adapter for the 7 pin plug to a four pin. I wired from the truck back to the hitch on the fiver and I have a separate 7-pin in the box for the fiver. I tow a boat behind the fiver. I also have a GMC. Another way is to tap into your tailights on the fiver for your power to the extra trailer.
Just Me & DW
2008 GMC 3500 SLT DRW Diesel
Pioneer AVIC D3 GPS Nav/Stereo/backup camera
2007 276RLS Cougar 5th wheel by Keystone
Scooter Buddy 125
17.5 Crestliner Boat
For those of us who fought for it, freedom has a flavor the protected will never know.
bubba1wig
Arlington, Texas
Posted: 05/29/08 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
I wired mine like Martyn did. Pulled the underbelly pannel off and spliced into the trailer wires.
Bob
'02 Sea Hawk 29 fks triple slide
'02 Chevy HD2500 crew cab Duramax & Allison
Pullrite Superglide-Prodigy-TTT mirrors
Bob & Sue
F4whlr
Warwick RI
Posted: 05/29/08 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hi All ! If anyone is interested in an additional plug and harness for their fifth wheel go WWW.ETRAILER.com they have almost anything you could need...all easy plug in into OEM harness just my .02
F4whlr
Dave C.
