HanksLBZ
Dixon,ca
Has anyone had any issues with the inside door material (wood) detaching itself from the metal frame? This is happening on my T23AK and the siding is bowing out and now unattached at the top of the ramp door. To repair this, is it as easy as taking the plywood off the frame and trying to nail or staple it back together and possibly reinforcing it?
thanks
06 CHEVY 2500HD Duramax diesel/Allison tranny(with some Xtra power)
04 Attitude T23AK
96 Yamaha Warrior (hers)
04 Yamaha YFZ450 (mine)
JJ&kids
North Tustin, Ca
I haven't had any problems with mine
I have an 08 about 1 year old now
03 Chevy 2500HD Duramax/Allison Crew Cab Short Bed
08 Attitude T23AK
01 660 Raptor
02 Yamaha 350 Warrior
04 Honda 250EX
04 Suzuki Z400
cumminspower79
Imperial Valley
On my attitude ramp door im have a problem with that cheap metal trim around the door, it started coming off the first couple of time I loaded my rhino. Im going to replace it with some angle iron.
2002 Dodge Ram 4x4 Cummins Turbo Diesel
2007 Attitude 26FSAK 2006 Yamaha RhinoSE
JJ&kids
North Tustin, Ca
cumminspower79 wrote: On my attitude ramp door im have a problem with that cheap metal trim around the door, it started coming off the first couple of time I loaded my rhino. Im going to replace it with some angle iron.
I have the same problem with mine. If you spin the tires at all on that edge it bends.
I went to a metal supply co. I found a 3/4" x 2" aluminium about $25 per 8' stick. When I have enough bends in mine and an extra $100 I will fix mine.
code3run
S. CALIFORNIA
No problems with mine so far. I love my trailer!
2008 ATTITUDE 21AK
2007 Dodge Ram 1500 hemi 5.7 lit
07 Yamaha ttr 50-SOLD
07 Yamaha ttr 90
07 Yamaha ttr 125
01 Yamaha yz 125
2 boys 9 and 12 and wife
Dusty the dog
Strabo
Desert Dweller
Dont load the ramp with it off center, use blocks of wood to make it level before you aproach it to load.....
2005 Ford F150 SC FX4-Procomp 6" lift-Fabtec Lightbar-Magnaflow 3" CB-K&N C.A.I-Firestone Airbags-Prodigy-Overhead DVD
2003 24' Jayco Talon ZX TH
2007 Rhino 660 SS106-ITP-K&N-JetKit-T4-CDI-CVT-Grant-Holder LED LightBar
1992 CR 250
1995 KX 250
HanksLBZ
Dixon,ca
Well, I tore into the ramp this weekend and figured out how they build them. The OSB(plywood) is installed on the metal ramp frame and then the 2x2 interior wood frame is stapled to the OSB. Then the siding is attached to the 2x2's. Staples do not hold very well if not used with glue, which they didn't use. All I had to do was use 1 1/2" wood screws and screw through the OSB into the 2x2's and essentially suck it back together. I still have to caulk it though.
I always make sure the ramp is blocked and secure before loading. Other than that I still like the trailer very much.
JJ&kids
North Tustin, Ca
I'm glad you found the problem and are able to repair it without major surgery
