doko
binghamton
Novus plastic clean and shine.
No personal experience, but the write ups look good for this sort of issue.
I just purchased for my car, but haven't used yet.
doko
wny_pat
Western NYS
Buy new lenses. The UV coating is gone on the ones you have and if you polish, they will return to the same shape they are currently in no time at all.
Busdriver
Shepherdsville Ky 40165
I saw on Two Guys Garage that you can use toothpaste.
Busdriver 2005 F350 Power Stroke - Sunnybrook
1fastdad
mo.
I have used toothpaste and a damp cloth with good results.
brobox
Sunny SW. Florida
I just purchased at Wal-Mart the other day the "Power Ball" to polish myMother Power Ball aluminum wheels. They also have the "plastic lense restorer" to work with the power ball. Looks to be a nice product and you can't go wrong with Mothers products.
Chuck
02 Travel Supreme, 2 street side slides
02 Jeep Liberty Toad
Tom N
Sarver, PA/Crystal River, FL
Toothpaste.
"The people that don't believe in evolution are the ones who need it most!"
Sarver, PA/Crystal River, FL/Indiana, PA
2005 Itasca Suncruiser 38R 38' 11"
W24, Allison 2100MH, full body paint
2008 Honda Odyssey EX-L, Roadmaster Sterling bar
FMCA 335149
BWhite
Metrowest,Ma
Novus #2 or Flitz
Bill and Patti
Gizmo a Black face Tri-color Pembroke Welsh Corgi
Laci a Red and White PWC
06 Fleetwood Revolution LE 40E
05 Hyundai Elantra Toad
Member, Revolution Owners Group,FMCA,CAT RV Engine Owners Club
www.revolutionmotorhome@yahoogroups.com
BobMary8101
Lake County FL for the winter
Thanks for all the suggestions, I just picked up some stuff at the auto parts store and will let you all know how it works. WNS_PAT, I would like to replace the lenses but I think polishing will be a lot cheaper. Besides, I am retired so the polish will give me something to do. Repeatedly
Bob
Bob and Mary
Pace-Arrow Vision 36B
Ford V-10 36 feet
Toad: 2008 Ford Focus
FMCA F398511
Maintcpo
Central California
I found this on another website to restore headlight covers. Probably the same material I would think!
The following is the procedure I use to get headlights as clear as new.
Tools needed:
Foam Sanding Block
400 Wet-sand Paper
600 Wet-sand Paper
800 Wet-sand Paper
1000 Wet-sand Paper
1500 Wet-sand Paper
2000 Wet-sand Paper
Bucket
Dish Liquid
Sponge
2" Painters tape
PlastX⢠Clear Plastic Cleaner & Polish
Step 1: Mask off surrounding panels (Bumper, fender, and hood). This is to prevent you from sanding through the paint on the panels.
Step 2: Put all sandpaper in bucket, fill with water and a little Dish liquid (dish liquid is used to allow sandpaper to glide easier. W/O it, it can sometimes become like a suction cup and be very difficult to sand)
Step 3: Soak sponge and then use it to wipe off the headlight lenses to get any loose dirt off.
Step 4: Wrap 400 grit paper over foam sanding block and get busy. I like sanding in 1 direction and then going an opposite 40* for the next grit. Its easier to see where the sand scratches from the previous paper is and you can tell when you get rid of all of them.
Step 5: Continue sanding with 400. After a few minutes, wipe off lens and allow it to dry. You will see areas that are still yellowish and/or somewhat clear. You are going to want to keep wet-sanding until when the lens is dry it is completely white with no color changes.
Step 6: Once it is all completely white, go to the 600 at 40* to what you were previously sanding until 400 grit scratches are removed.
Step 7: Repeat step 6 working your way up, changing sanding direction from grit to grit until you get to 2000. When wet with the 2000, it will be somewhat clear... and most likely already look better than it did when you started depending on how bad your lights were in the 1st place.
Step 8: Now that you are done sanding, dry off the lens and any water off the surrounding paint.
Step 9: Now that it is all dry, its time to break out the buffer and PlastX. Apply some PlastX to the lens and buffer pad. At 1st just tap the trigger so the pad and PlastX gets spread out, if you go all out at the start, it will fling the PlastX all over the place.
Step 10: Continue buffing. Don't stay in 1 place too long and go from headlight to headlight. If you stay in place too long it will heat the plastic, causing it to yellow, and if real bad, it could warp it and possibly even create bubbles (this would take a good amount of heat to create bubbles... not sure if you could do it with a buffer).
Step 11: Buff until entire lense is clear. The light should look brand new providing you never had anything leaking inside of it.
Step 12: Pull off masking tape and give the car a wash to clean off any PlastX that may have flung.
Dan, Ret Navy CPO
Minnie The Wife Extraordinare
Chris Our Son the Genius
3 Dogs 1 Dumb , 1 Fat and Stubborn, and 1 new and Adorable
2005 Jazz 2550RL 5er
2003 Dodge Quad Cab Long Bed Cummins 6 shooter
enblethen
Moses Lake, WA USA
Most of the rigs do not have replacable lens. There are an assembly. My pace actually has Ford pickup or van headlight assemblies.
Bud
Suzuki XL7 pushing Pace Arrow
