RV.Net Open Roads Forum: Proper procedure for plugging into a 50 amp service
 > Proper procedure for plugging into a 50 amp service
shooters
Southern Calif
Posted: 05/30/08 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guys.
If this topic has been discussed before, then please forgive me. I did a search and didn't locate much on the topic.
My RV dealer says there is a proper way to plug into a 50 amp service in an RV park. I was told to turn off the breakers to both the coach and the parks plug.
Does anyone have any further infor on the best way to hook up to 50 amp so you don't blow you electrical out of the coach?
Thanks much.
Hornet28BHDS
Parker, PA
Posted: 05/30/08 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
When I plug in our cord, I don't mess with the breakers and have never had any complications. Good luck!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Ultralife
West Coast, USA
Posted: 05/30/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure the breakers at the source are off before plugging, then turn them on. You risk the chance of burning the blades of your plug if you don't.
Where you are is where your at!
2002 Beaver Monterey 38' DP 330HP Cat
2002 New Beetle "Silver Bullet" Turbo Sport (Manual 5-speed)
Blue OX tow bar and base plate
Who says AZ summers are hot???
Don and Pat
trnfla
Tampa
Posted: 05/30/08 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Turn off the breaker on the pole, plug in your camper then turn the breaker back on.
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
shooters
Southern Calif
Posted: 05/30/08 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
What about turning off the breakers to the coach as well?
swebber
Brunswick , MD
Posted: 05/30/08 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
I do as Ultralife and trnfla do, turn breakers off, plug in, turn breakers on.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
RCFlyer
Washougal, WA, USA
Posted: 05/30/08 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, what hey said. I don't know why you would need to turn off the breakers at both ends - the main issue is to protect the plug blades, so shutting off the breakers at the pole/hook-up is all you need IMHO.
2005 F-350 SRW LB Black Harley Davdsn, 6.0 Pstroke w/auto, Excite liner, ARE "Z" cap w/Yakima rails & slide/tilt window, PIAA 1500 bu lights. B&W TO Ball hitch, Firestone bags
Wife: Stef the quilter
Dog: Chase, the Golden Retriever
3 sons, 8 grandkids
Jerry_Keller
Posted: 05/30/08 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Just turn off the breakers on the shore power. That's more than enough.
Jerry Keller
2006 Bounder 35E, W22
RCFlyer
Washougal, WA, USA
Posted: 05/30/08 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, what they said. IMHO you don't need the breakers off at the trailer panel.
Big Katuna
Deland, FL
Posted: 05/30/08 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
I also make sure my AC's are off before I turn the breakers on or off. I just do the breaker(s) at the CG pole.
My Kharma ran over my Dogma.
