RV.Net Open Roads Forum: Class A Motorhomes: shower water pressure
 > shower water pressure
jeeperman
florida
Posted: 05/31/08 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
hello everyone, I'm just pursuing getting more pressure @ the shower head, the hose is off @ the valve, I see the water restrictor, question- does that insert pop out or do I need to drill a bigger hole ?. I'm not to crazy about uping the pressure @ the spicket that reg. is @ 50psi to the hole coach.
CSpenceFLY
Macon,Ga
Posted: 05/31/08 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
I would start by making sure you don't have a restriction in the head or a clogged screen or filter.
"You're lucky to be alive my friend."
Quote from the "Do it yourself police" and many others that have known me.
RedRamMan
Northeast Kansas
Posted: 05/31/08 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
I just drilled mine. Works fine now
2004 Red Ram SLT QC 3500 Auto CTD HO SB
2001 Cedar Creek 25RLMS 5er
Wherever I happen to park
Posted: 05/31/08 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Does the water restrictor pop out or do I have to drill? A: YES
It depends on your rig or rather the shower head in the rig.
I have a collection of water pressure regulators
1st is an old (I mean VINTAGE old) Marshall Brass standard.. It will not pass enough water to feed the thing (I may have tossed or recycled it)
2nd is a "High volume" this one too is one of the same shape but it has a bigger passage so it almost, I mean ALMOST passes enough water to make me happy
3rd is a Watts.. It works wonders
Larry Cohen
Mobile, AL
Posted: 05/31/08 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a whole house filter make sure it's not clogged...mine was...huge difference when changed!!
2006 Mountain Aire 43
Wife, K9 Maggie and 4 sugar gliders are co-pilots, along with Garmin Nuvi 660
06 Vue AWD toad with Brakemaster
Blue Ox Adventa II towbar
Tinstar
McKinney, TX
Posted: 05/31/08 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
I drilled mine and it didn't help. I changed my old regulator to a whole house Watts and now I have no more problems.
Never pass up a chance to go somewhere
tropical36
Southwest Florida_USA
Posted: 06/01/08 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
I removed my built in regulator...and don't use the common inline at the facuet either....my setup begins at the supply end with a whole house regulator (watts or other) that adjusts the pressure without decreasing the volume) a filter is attached to that...then the hose to the coach. There is where I removed the OEM regulator and installed a brass garden facuet.... then removing the valve stem and capping it off so it wouldn't look ridiculous. In between that and the hose is a pressure gauge. It makes for a professional looking set up that works very well.... meaning that the coach has full volume everywhere at the 40 psi input. I might add that I don't assemble anything when hooking up....just drag out the hose assembly and screw it on. Also I usually use a splitter to get the desired angle for my large filter and at the same time, provide an another facuet outlet for whatever.
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal, with a tag axle and one slide, on a 1997 P32 Chevy chassis....7.4 Vortec Engine
T bone
Top O Texas
Posted: 06/01/08 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Go with a Watts house regulator, you won't be sorry.
1999 Georgetown 325S,V-10 Ford.
2002 Ford Ranger Edge toad
carrying a 2001 Yamaha Warrior.
jeeperman
florida
Posted: 06/02/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the advice, I think I found the watts reg. on ebay, do you have the H560G looks like it has hose connectors & a gauge the factory set psi is 40 it go's from 10 to 60 psi.??
Larry Cohen
Mobile, AL
Posted: 06/02/08 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I think that is the one I have....it has large bore internals of about 1/2"..unlike many others that are about 1/4"..and that is what affects the flow..
