RV.Net Open Roads Forum: Tech Issues: No Cruis Control with lights on?
 > No Cruis Control with lights on?
sjptak
Seymour, CT
Posted: 05/31/08 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
We just went from CT to MI in our new to us 99 Four Winds 28A on a Chevy chassis. I used my lights to signal a trucker that it was safe to pull back in on the Interstate, and it shut down my cruise control. Is this normal? This means I have no cruise control at night?
Off to See the Lizard
'99 Four Winds 30' Class C
'97 GEO Tracker
'63 Honda 305 Dream
1947 Wife
1949 Me
sum1
So-Cal
Posted: 05/31/08 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Perhaps a bad ground or crossed wire is backfeeding the brake light circuit.
Gale Hawkins
Murray, KY
Posted: 05/31/08 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
I agree that sum1 is on the correct thought path. There was a tread on that once. It gives a signal like you hit the brakes or a huge bump perhaps. I guess you could just run on dim.
fatmanobx
kill devil hills, n.c.
Posted: 05/31/08 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
My last C did the same thing. I was also told it was a ground, but never was able to find the problem and have traded it off since then..
2003 Four Winds Infinity 37'
wwest
Redmond WA
Posted: 05/31/08 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
If the brake lights come on the cruise control is cancelled. Look for a short from the tail light circuit to the brake lights. Check the bulb sockets.
sjptak
Seymour, CT
Posted: 05/31/08 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
I'll have to play around with this a bit. I don't drive much at night, but, it's just plain annoying. Thanks for the ideas. I'll just have to find some time to play with this a bit.
Wherever I happen to park
Posted: 05/31/08 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Poor ground, Tail lights
The cruise control has a number of sensors.. One of them senses power across the brake light switch.. In normal operation there is 12 volt across the brake light switch but if you step on the brakes.. Well, then there should be zero volts ACROSS the switch (Both sides are at 12 or more likely 13.6, volts, differential is thus zero)
So if your brake lights are burned out... (The are the path to ground) your cruise won't work
If the brake light switch shorts out The cruse control won't work
And if you have a bad ground on your tail lights EIther bulb to socket or socket to chassis, When you activate your tail lights.. THEY "Back feed" the circuit and your cruise control won't work
trnfla
Tampa
Posted: 05/31/08 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like he bought your unit...
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
Bessie-Hunter
Lyons, OH, USA
Posted: 05/31/08 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
If your bright light switch (Flash to Pass) is on the turn signal lever like most others now days are, along with the cruise control, chances are you have a broken wire in the turn signal stem assembly. Replacing the stem would cure the problem.
Dave & Ellen, Don and Ross
'04 Dodge Durango 5.7 "Ya, it's got a Hemi" 3:55
Reese Dual-Cam WD
Jordan Ultima 2020
'05 Surveyor SV255RS
