RV.Net Open Roads Forum: I asked the CHP how they determine load rating of TV's
Search only in Tow Vehicles
 > I asked the CHP how they determine load rating of TV's
EPenney
Galt, Ca
Posted: 05/31/08 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Went to a truck show today....semi's on display mostly.
While there, I stopped by the CHP booth. I asked the officer what determines max load rating for vehicles towing RV's in CA. The answer was tire ratings. He told me if he thinks a vehicle towing and RV is overloaded, and he pulls it over, he will look at the tire ratings and will weigh the rear axle. He said as long as the axle weight is under the combined load rating of the rear tires, then the vehicle is not considered overloaded.
I told him if that was the case, then if a TV was loaded right up to the GAWR, then it would exceed the mfg's GVWR. He said yes it would, but that the GVWR is a mfg's rating only, and is not considered by the CHP when determining if a vehicle, such as one towing an RV, is overloaded.
I think he got curious why I was asking the question about max weight, because he asked me if I had a trailer, and I told him I had a 5er. He then asked what the GVWR was for the 5er, because there are DL requirements based on trailer GVWR. I told him I was up on the requirements, and took my license out to show him my restriction 41. I got an "Atta Boy" and a CHP sticker for being aware of the DL law.
'07 Chevy 2500HD Silverado "Classic" CC D/A 4x4
'07 Komfort Trailblazer T252FS fifth wheel
Reese Signature 18K Slider and other stuff.....some useful.....some not
HarleyMedic
Sour Lake, Texas
Posted: 05/31/08 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
I got a smiley face sticker at Wal-Mart the other day, does that count?
Big Sexy and BonBon
2003 Dodge 2500 4x4 Laramie Cummins Auto, Edge EZ, AEM Brute Force, Timbrens, B&W.
2004 35SRV Victory Lane
1998 Harley Road King (Mine)
2003 Harley Road KIng (Hers)
2004 Yamaha Grizzly LE
Gale Hawkins
Murray, KY
Posted: 05/31/08 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Did you point out the kinds of rigs that most likely might be overweight based on his system?
Serious it it good to hear they deal with the practical and provable. Did he say if he checked the PSI to insure the max load rating applied? Did he say they just do not stop MH's over weight issues if they are not towing?
CISCO8325
Peoria,az.
Posted: 05/31/08 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
I sleeped at the holiday express, cause I can't aford gas? way to good good job
352
Oxfofd, Fl
Posted: 05/31/08 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
be careful harleymedic.i got bumped for saying (wow)
1937(BAD BOY)pontiac,all steel,chevy 350,dyno=405hp,650 holley double pumper,ps,pb tilt wheel,heat & air,
700 r4 tranny,headers,3" exhaust with flowmasters.
just a good ole southern redneck country boy.our favorite place to go to swim with the manatees
Doug and Cassi Glass
Clifton Forge, VA
Posted: 05/31/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
The CHP sure has changed since I retired in 2003. Rarely, if ever does a beat cop stop somebody for suspecting its overweight. And unless he has portable scales with him, by law he can only take you to a scales within five miles.
Commercial officers, the guys driving pickups are different. They have much more training in that arena and MIGHT take an RV to the scales if his portables are broken, but the chances of getting hit by lightening while holding the winning powerball ticket in your hand is much more likely. There are far too many truckers running amuck to screw around with RVs.
They might stop you if they want a closer look at your rig or have RVing questions.
As a footnote, the commercial guys that worked for me in the San Joaquin Valley would usually weigh your rig if their scales worked and they had them out. They weigh about 60-70 pounds each and are in for repairs most of the time.
EPenney
Galt, Ca
Posted: 05/31/08 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
The fellow I spoke with was a commercial officer. And yes, I got the impression that RV's were the least of their concerns when enforcing weight regs. He did say he carries scales with him.
I, up until today, thought that in CA max load was determined by the GVWR, but apparently I have was wrong.
ernestfortier
Palmdale, Calif.
Posted: 05/31/08 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
The Calif DMV Handbook has all the needed information. They go by the max limit of 18,000 per axel. After that they go by the weight rating of the tires. The Manufacturer GVWR could be changed up or down just by which radiator they put in the pickup.
Ernie Fortier
99 Bounder 34V
2 honda 2K paralled (for economy)
5.5 Onan onboard
96 Geo Tracker 4x4 Auto. convertable
trucker495
Linden, CA
Posted: 05/31/08 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
I gottta tell you that in 12 years of being an owner operator running in CA I have yet to see a CHP pull a big rig over and weigh it on their portable scale! I am not saying they don't just saying I have never seen it nor do I know a trucker who has. As far as overweight RV's they can't even begin to properly police the trucking industry let alone the RV's on the road.
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 05/31/08 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
As long as you are not doing something stupid no self-respecting CHP/HWP officer is going to mess with you. All I have talked to say they look at tires and as long they look inflated and you are not squatting in the rear you won’t get a second look.
With that said the OSHP are all trained in commercial enforcement and can tell if you are over weight just by looking at your rig. And yes here in Ohio they will pull an RV over if they think you’re over weight and call for the scales to come and weight your set-up.
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
pics
