pcm1959
St Augustine, FL
While enjoying the wonderful Memorial Day week stay at Henderson Beach State Park, FL, this week, I decided to climp up on the roof to do a visual inspection of my our 14 month old Sydney 31FRKS fiver roof.
What I discovered alarmed me somewhat - especially since the unit is 14 months old, I figure it's our of warranty. On the trailer right side, under the rubber roof, the roof decking is not fastened down where it meets the side wall. It is like this in 2 places - between 2 of the boards. It has not punctured the rubber membrane, however, I think it should be fixed. I hae done a few searches and found that this can happen on any rv due to various reasons. Seems the most common is shoddy workanship. However, at any rate, I'd like to have it repaired.
Has anyone else experienced this and what did you do to repair it? Am I correct in the assumption that it is out of waranty now at 14 months old? Thanks for you help. PCM
weekendrvers
Iowa
Hi I think you have a 10 or 12 year warranty on a roof? ~~Especially due to a obvious manufacture defect?~~Sandy
New Everest Owners~~~
Steve, Sandy, Katie and Our Cocker DJ
We Love our new 5er it is totally awesome to camp in
Literally like a Condo on wheels!~
2007 345S
2008 Ford F350 King Ranch Diesel CrewCab 4x4
pcm1959
St Augustine, FL
I think the rubber roof membrane is warranted for 10-12 years. However, I do not think the structure is. PCM
donhov
near Jackson Michigan
I would contact my selling dealer and see if they will assist you. Sounds like a future nightmare developing so so it soon.
2003 Cedar Creek 30RLBS
2007 Dodge 5.9 Cummins Turbo Diesel 325hp/610Tq
4x4 3.73 axles short bed
Inferno Red W/Gold pinstripping
pcm1959
St Augustine, FL
I have heard that the roof decking is glued-not screwed-to the roof rafters/trusses to avoid a screw back pooping loose and enetrating the rubber membrane. That makes sense.
Also, that the decking boards should not be fastened down at the waal edge to allow for flex.
If both these statements are true, then my situation is OK provided the decking board is not so loose it would raie to the point of poling through the rubber.
Any thoughts? PCM
ChainReaction
Maine
Have seen this on a few units. Usually the deck is glued and screwed on the higher end units, just screwed on the more entry level ones. To fix, the edge cap will need to be removed, the rubber roof lifted back and the screws that "missed" replaced. Then reassembled. Should only be a 2-3 hour job for most shops, full day for do-it-yourselfers. A rolling ladder or "baker" staging makes it much easier. Your manufacturer should stand behind it as this is not wear and tear related.
pcm1959
St Augustine, FL
ChainReaction wrote: Have seen this on a few units. Usually the deck is glued and screwed on the higher end units, just screwed on the more entry level ones. To fix, the edge cap will need to be removed, the rubber roof lifted back and the screws that "missed" replaced. Then reassembled. Should only be a 2-3 hour job for most shops, full day for do-it-yourselfers. A rolling ladder or "baker" staging makes it much easier. Your manufacturer should stand behind it as this is not wear and tear related.
I would agree. Do you think Keystone will stand behind this situation since it is 2 months out of warranty now??? PCM
lv2rom
Kansas City, Missouri
pcm1959 wrote: ChainReaction wrote: Have seen this on a few units. Usually the deck is glued and screwed on the higher end units, just screwed on the more entry level ones. To fix, the edge cap will need to be removed, the rubber roof lifted back and the screws that "missed" replaced. Then reassembled. Should only be a 2-3 hour job for most shops, full day for do-it-yourselfers. A rolling ladder or "baker" staging makes it much easier. Your manufacturer should stand behind it as this is not wear and tear related.
I certainly think they will....if not, go public (Trailer Life, etc), I'll bet they step up then....Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
floridacamper
Florida/Georgia Line
lv2rom wrote: pcm1959 wrote: ChainReaction wrote: Have seen this on a few units. Usually the deck is glued and screwed on the higher end units, just screwed on the more entry level ones. To fix, the edge cap will need to be removed, the rubber roof lifted back and the screws that "missed" replaced. Then reassembled. Should only be a 2-3 hour job for most shops, full day for do-it-yourselfers. A rolling ladder or "baker" staging makes it much easier. Your manufacturer should stand behind it as this is not wear and tear related.
My Keystone Cougar roof started leaking at 16 months, 4 months out of warranty and I was told by both my dealer and Keystone that I was on my own. Good Luck!
The ten year warranty on the roof only applies to the rubber deteriorating .
If they don't won't to cover it I would contact who you have it financed with and tell them what's going on.
I would call my dealer and Keystone today, every day that passes is a another day out of warranty
CLICK HERE FOR PHOTO ALBUM
pcm1959
St Augustine, FL
Yeah, I'm not getting my hopes up. My roof is not leaking. But the roof decking is detached from the trusses/rafters and pushing up the rubber membrane. Sound like a factory defect to me due to lack of poor glueing or staples. Don't know if that makes a difference. PCM
