RV.Net Open Roads Forum: How long does it take you to dump....
 > How long does it take you to dump....
bfast54
Traverse City ,Mi.
Posted: 05/31/08 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
Mine also, about 5-6 min
* This post was edited 06/01/08 06:23am by an administrator/moderator *
1994 Dodge Cummins Turbo Diesel,3500,Dually (Oh YEA )
1991 Ford F-150
1993 Sandpiper 5th Wheel)
Prodigy Brake Controller
Honda EU3000is Generator
Raytek IR Thermometer,Garmin C-330 Nav./GPS
Doran Pressure Pro
Rally's attended so far- 8
My Blog
Aridon
SE Florida
Takes us about a minute per tank for them to dump then another few minutes to flush and such. Shouldn't take 3o mintues unless you have a partial blockage or something in there.
2008 Newmar 4330 (Modified)
old guy
Oregon (pronounced Or e gun)
Posted: 05/31/08 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
sounds like you need to put more water into the black tank before you dump. it should help to liquefy the dark matter to help it flow better.
bldrbuck
Boulder, Colorado
Posted: 05/31/08 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Unique M and M -- Home/RV This makes everything liquid for faster dumps.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
D.R.Bain
Michigan
Posted: 05/31/08 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
with a 2 to 4 bowl rinse, and washing my hands before I move the MH it still takes less than 10 minutes.
* This post was edited 06/01/08 06:24am by an administrator/moderator *
Dan, 2007 Damon Daybreak 3270
Tinstar
McKinney, TX
Posted: 05/31/08 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
Both tanks will empty in less than two minutes, give or take a few seconds. There is a problem if your tanks are taking that long. The shop people don't want to fix them if they are telling you that your time is normal. I guess you can see from the responses that 5 minutes is about average.
Never pass up a chance to go somewhere
bill h
el segundo
Posted: 06/01/08 12:05am Link  |  Quote  |  Print  |  Notify Moderator
Our last dump was about 25-30 gallons, and took just under two minutes, from coach stop to coach drive away. I am still there rinsing the hose while she pulls away and the next guy pulls up. Then I walk over and stow the hose and we leave. No tank rinsing.
If I really wanna be quick, I hook up the hose while waiting for the guy ahead of me, and walk along holding the hose while the wife drives up to the station, it is a little quicker.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
hottubkid
SCHAUMBURG,IL
Posted: 06/01/08 04:34am Link  |  Quote  |  Print  |  Notify Moderator
Suggest next time you camp, you try filling the black water about half full and drop a bag of ice down the toilet just before you leave. Likely you have a parshal blockage and this might help
doko wrote:
your tanks
I ask because when we purchased the coach (newmar canyon star 08) it would literally take about 1/2 hour. We had them add some blocks to improve the pitch and now will still take about 15min. There is about 10 feet of tube between the tanks and the dump.
It helps if we are level or leaned toward the dump site, but this is not always possible if waiting on line to empty.
This is not an issue if we have full hookup, but if we are on a line, people are not going to be too happy if we take 15+ minutes.
Any other tips or suggestions for speeding up the process?
doko
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
oldvectra
Lothian, Maryland
Posted: 06/01/08 04:58am Link  |  Quote  |  Print  |  Notify Moderator
If it takes a long time for both maybe its the vent that is clogged or blocked somehow. It its one or the other then possibly something got in that tank during construction since it is fairly new. Has it always been like that?
2002 Holiday Rambler Endeavor 38PST
330 ISC
doko
binghamton
Posted: 06/01/08 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Thx for your replies. I believe the issue is actually a design flaw as there is a huge amount of pipe coming from the tanks and originally they were essentially parallel to ground.
With added pitch it immediately cut down 15min on the dump time and I suspect more pitch is needed but may be physically impossible do to design. I know that there is no blockage as they have checked that out.
I'm bringing the unit back to factory for them to look at this issue next week. Thanks for confirming that 5 minutes is about the max it should take just to dump.
doko
