RV.Net Open Roads Forum: Tech Issues: Coleman Generator - Leaking Fuel Cap
 > Coleman Generator - Leaking Fuel Cap
Crumm
Fairbanks Alaska
Posted: 06/01/08 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
I hesitate posting this here as I know the help I am going to get is "buy a Honda". I have a couple of Honda ATVs and a LARGE Honda Generator but my small Generator is a Coleman and I don't have the funds right now to buy the Honda 1000 that is on my wish list.
I have not used the Coleman in a few years but this last week I needed to top off the camper batteries while in the boondocks. After it ran for a few minutes there was fuel running out of the cap and down the side. I looked the cap over and didn't see anything broken. There appears to be a couple of tin disks with a piece of foam between for a vent and a cork type gasket for a seal above the threads. The fuel seemed to be coming out of the vent. Anyone else have this problem? I am wondering if the cork is leaking air allowing fuel to go up the vent? Is there replacement caps available and if so where? Will a new cap fix it?
96' F350 PSD with smoke added, Airbags, Trailmaster SSV shocks, 315/75R16 Toyo M/T, Centering guides.
06' Adventurer 90FWS with leg extensions
06' Jetcraft XS.
94' Wells Cargo 7'x14'
Slide-Show
fireman50
Tennessee
Posted: 06/01/08 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Was it sitting in direct sunlight ? The heat could have caused a pressure build up in the tank and caused it to burp fuel, which is what it should do since the cap is designed to vent.
Crumm
Fairbanks Alaska
Posted: 06/01/08 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
In the shade. Temp in the low 60's. 3/4 tank of fuel.
Kenneth
Washington, the state
Posted: 06/01/08 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Powermate Corp., the maker of the generators with the Coleman label, files for bankruptcy in March. Try for a replacement cap, and good luck.
http://www.powermate.com/
Buy the way, the Coleman name has been widely bought and sold.
Jarden makes Coleman camping products.
York makes Coleman home furnaces.
Air Xcel makes Coleman RV air conditioners.
Fleetwood used to make Coleman trailers.
