RV.Net Open Roads Forum: Class C Motorhomes: Exhaust extension for Gen
 > Exhaust extension for Gen
M GO BLUE
Southgate, MI
Posted: 06/02/08 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Gen-Turi works great and would not be without it...takes less than 5 minutes to install...as a sidenote I purchased 2 rather large suction cups and use thse to hold the GenTuri in place...they provide 2 hooks with permanent adhesive on one side or 2 rivets with hooks attached (didn't want to do either to a new fiver so I opted for the suction cups...about 3" in diameter)
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fith wheel
Built-In Onan 5500W generator
rvten
Crossville,TN
Posted: 06/02/08 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Nothing !!
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008
Class C passed Class A owner
Pontiac G6
There is NO such Thing as a B+
Not a Clue
Southern Ca
Posted: 06/02/08 09:34am Link  |  Quote  |  Print  |  Notify Moderator
I don't want to be poking holes in my MH either. Where are the hooks placed? Where did you get the suction cups?
Linda B.
2009 29' Fleetwood, Fiesta V10 - The Big Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
Traveling with Robin(friend),Liz(cockapoo)&Buddee(cavalier)
Polishnurse
Schodack, NY
Posted: 06/02/08 09:35am Link  |  Quote  |  Print  |  Notify Moderator
sreeder - you had better check you periodoc weight tables, I beleave you will find that Exhust gas as just a we bit heavier then air you breath.
I leave a 3 to four inch air gap bettween the elbow and the up pipe, and have found that there is plenty of up draft. So much so that after four hours of operation, the raiser pipe was only warm to the touch at the inlet, bottom end. Good Luck and happy venting.
Sreeder - just another note, some places like the meadow lands now require such epuipment if you wish to run you generators. To many people were tryin to kill each other at the tail gate parties. They have have also found that the air stays much cleaner when there used.
Simon3xUD
Baltimore, MD
Posted: 06/02/08 09:53am Link  |  Quote  |  Print  |  Notify Moderator
I've asked this previously and never got an answer - those of you who have and use a Genturi, does/did your genny exhaust pipe have a spark arrestor in it? Mine does and the screw that holds it in place prevents me from sliding the flange(s) on to the pipe by the specified 2". Just how critical is it that the 2" specification be followed?
Any help would be appreciated!
Sally and the agile Aussies
2007 Sunseeker 3100LTD
M GO BLUE
Southgate, MI
Posted: 06/02/08 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Got the suctio0n cups from Walmart in the Hardware/Paint section...3" in diameter and the hook part snaps down to make sure you have a good seal to the side of the RV
CISCO8325
Peoria,az.
Posted: 06/02/08 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
here is website where this guy built it.
http://groups.msn.com/PopUpTrailerCamping/homebuiltgenturi.msnw
oujoker
Monterey, CA
Posted: 06/03/08 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Polishnurse wrote:
I picked up some of the suction cup holders for Harbor Freight. A length of (10') of 3" PVC from Home Depot. Cut the Pipe in Half and mounted the suction cups on each piece. Took the end with female coupling formed in the pipe, and slide that over other piece. So now I have the a 10' that breaks in half for storage. then Picked up an 1 1/8" electrical EMT 90 degree bend. that fits over the exhaust and blows the exhaust up. Suck the PVC on the side of RV with a 2" air gap over the EMT and no more exhaust. It's all up, up and away for about $35.00 total. JM2Cents Bill
Thanks for the tip! I will definitely be constructing one of these!
2007 Dutchman Express 31 Class C
2006 Centurion Elite V C4, Air Warrior
oujoker
Monterey, CA
Posted: 06/03/08 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Handbasket wrote:
Just be careful you don't create significant extra back-pressure in the exhaust with a DIY extension. This might lead to exhaust leaks in the generator compartment. Smaller Onan's have at least two joints inside the box that could leak, the internal muffler-to-tailpipe one in particular. Any leaks here could find their way into the living quarters.
Sreeder, I think the Genturi idea is to draw outside air into the exhaust stream at the bottom of the 'chimney' to mix with the exhaust, and thus dilute the CO. Plus roofs tend to be well-sealed; undersides don't.
Jim, "Mo' coffee!"
Thanks for the clarification of what is happening here.
Not a Clue
Southern Ca
Posted: 06/05/08 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info.
