RV.Net Open Roads Forum: What's the narrowest you have had to back up your trailer?
 > What's the narrowest you have had to back up your trailer?
VMark
Ca
Posted: 06/01/08 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
The width of my trailer is 9'. I have measured the space at the side of my house I plan on keeping the RV, and the narrowest point is 9.5'. Does this sound like difficult manuevering? Once I'm past the narrow point, the space expands to 10.5'.
DianneOK
Donnelly, ID
Posted: 06/01/08 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Have you figured in awnings, etc?
Dianne
Donnelly, ID
DataStorm
HAM WB6N (Terry)
2005 Teton 39' Frontier Grand
2003 Freightliner FL60
Life Member Good Sam
Escapees
Geocache..."RVcachers"
RV net Blog
VMark
Ca
Posted: 06/01/08 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, that is the total width. What keeps it narrow is my water meter, so everything above thigh height is unaffected.
LarryJM
NoVa
Posted: 06/01/08 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
That is tight and could be tricky depending on what obstructions are at the 9'6" area. If you have a straight shot and the ground is level it might be O.K. just take it slow and as already mentioned you need to account for awnings, etc. that add to the "normal width" of the trailer. If you have to maneuver then IMHO 9'6" is too tight.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
LarryJM
NoVa
Posted: 06/01/08 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
That helps since the slope is sort of out of the picture and that obstruction should be low. Just hug that meter and don't hit it. It might take some tries to align things up so you go straight in, but now this seems doable.
Larry
wanderer72
Canada
Posted: 06/01/08 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
The trailer should be no wider than 8'6" as this is the legal maximum width. Most travel trailers are 8'. If you are including the awning etc, this shouldn't make a difference if it's up high as your water meter from the house is down low. I'm sure with a flat surface and straight shot you will make it, if you need to turn the wheels slightly on the tow vehicle to get in or out of there It could be too tight. Go slow and giver it a try, worst case you have to drive it back out.
"A mind is a terrible thing to waste and a waist is a terrible thing to mind."
Hornet28BHDS
Parker, PA
Posted: 06/01/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
I think it can be doable. Take your time and be careful!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
mobeewan
Hampton, Va
Posted: 06/01/08 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Six inches of clearance on each side of an 18 foot TT backing between 2 trees. It was in a camp ground that was for tents and did allow pop ups. The owners allowed me to bring a small TT since was a preferred customer.
loveshack1
Whitewater, Wi
Posted: 06/01/08 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
I used to park our TT in my workshop (unheated side) and I had 2" of room on either side while the rear bumper just touched the rear wall and the tongue had 6" room.
DW thinks we should park the fiver in there, and I agree, but I'll have to modify - A LOT.
If electricity comes from electrons, does morality come from morons?
VMark
Ca
Posted: 06/01/08 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the advice. mobeewan and loveshack1, your reverse parking exploits are inspirational! I went out and looked at the space I have, and it now looks like a chasm.
