RV.Net Open Roads Forum: Class A Motorhomes: nervous!!!!!
 > nervous!!!!!
wildbill0013
aberdeen maryland
Posted: 06/01/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
i am taking a trip to gettysburg and have reserved a site with 50 amp service,my question is, can i use a 50 to 30 adapter to hook up my coach?
i am nervous about burning out my converter.
please help.
D & M
Laurel, MD
Posted: 06/01/08 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
No problem - not to worry
Dave & Mary
Isabel (a cuddly little Boston)
Buddy (The Beast) another Boston
2005 Itasca Suncruiser 35A
2003 Jeep Liberty
If it's listed in the Yellow Pages, the government shouldn't be messing around with it.
JohnnyT
Goshen New York
Not a problem.. Enjoy Gettysburg Depending on which campground your in the post will more than likely have a 30 amp outlet in addition to the 50 amp outlet. But even if it only has a 50 amp outlet your adapter will do the trick...
JohnnyT
kknowlton
Wisconsin Border Country, IL
Posted: 06/01/08 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Without knowing which CG you're referring to, I'm guessing that your 50 amp site will also have a 30 amp outlet. Just don't run everything at once - operate what you usually do on 30 amp, no more - and you should be fine, regardless.
JFG
TN
Posted: 06/01/08 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
Most 50 amp pedestals also have a 30 amp and 20 amp outlet. Yes, you can use an adapter.
Fred
fatmanobx
kill devil hills, n.c.
Posted: 06/01/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
I went camping last week and we had to use a 50amp ped. because the park was full. No problem, just bring your adapter with you. Wally World is a lot cheaper than a rv park if you don't have one and have to buy one.
2003 Four Winds Infinity 37'
wanderer72
Canada
Posted: 06/01/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Put your mind at ease, there is no problem with using the adapter and as mentioned most have 50 & 30 amp recptacles where no adapter is needed.
"A mind is a terrible thing to waste and a waist is a terrible thing to mind."
John S.
Northern Virginia
Posted: 06/01/08 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
I do it all the time in the Bornfree.
John
2001 42' Foretravel U320
2007 Bornfree 24 Painted
2001 Jeep Wrangler
2007 Burgman 650 Executive
Susie and Dolly (Cavalier King Charles Spaniels)
Dolly now in our hearts and thoughts 8-27-05
Doodle a Black and Tan Cavalier
Lolly a Ruby Cavalier
Wherever I happen to park
Posted: 06/01/08 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
Your converter will draw up the lesser of it's needs or the trip point of the circuit breakers feeding it, no more.. and it likely eats from a 15 or 20 amp breaker inside your rig
If you plug into a 50 amp circuit, using a 50-30 dog bone.. You might want to use a 15-30 plug in adapter and plug in your volt meter first If it says about 110-120. GO FOR IT
If it says 240 either the dog bone or the park has a problem.. And I'm guessing it's not the dog bone
PS.. Don't plug the rig into that outlet
NOTE: might not be a bad idea to use the needed adapter and plug in that meter ANY time you hook up
The Beave
Georgetown TX USA
Posted: 06/01/08 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Be sure to use the "dog bone" type adapter and not the short one piece adapters without a cord. The short adapters can get hot and can short out.
The Beave
30' 1997 Beaver Monterey
(The shortest DP we could find)
2005 Honda CR-V
Remco surge brake
 > nervous!!!!!
