gmaninpa
york
Has anyone replaced the middle portion on their screen door with the clear plastic insert, one is fixed and one slides over the latch? If yes, how do you remove the fixed panel? I can insert the movable panel but the fixed one seems to be part of the door?
rtazz17
east hampton connecticut
I installed mine right over top with those "things" from the home depot to hold a sreen window in a storm door...Not sure if you can use them or not in yours but I was able to in mine...I like to be able to remove it when I want to and this was the best solution...Hope this gives you an idea
dbbls
Missouri
There are two little plastic rivets that have to be removed then the solid plastic insert can be removed. I then replaced it with clear plex a glass. The rivets hold the vertical bar that forms the square that holds the solid piece.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
spepi
Mansfield MA
I just did mine...little plastic rivets, you can pull these with needle nose pliers, bend out the old one, but vertical bar back in, put rivets back in, then instal slide...very easy to do
DW, 2 Teen's, 2 Dogs
05 Chevy Trailblazer (I know...its small)
3.42 Gears
Prodigy Brake Control
Reese 800lb Weight Dist Bars
Dual Cam Sway Contol
2008 Rockwood 2701ss
gmaninpa
york
thanks, I'll try that tomorrow.
z_i_m
alabama
on ours, we just have to fold it a little and it will come right out of the track with no damage............
