RV.Net Open Roads Forum: Travel Trailers: bad axles?
Open Roads Forum  >  Travel Trailers  >  Vintage TT's
 > bad axles?
airstreammama
Wy
Posted: 06/02/08 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
How do you know when you have bad axles? We need to replace tires, and I noticed that our airstream sits a little low. Is there a test, or a way you can tell?
PatSak
Orlando, FL
Posted: 06/02/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
If it is a new trailer and still under warranty, I would take it back to the dealer and have him look at it. Tires wearing out ahead of time is one of the signs. Is it uneven wear?
2008 Trail-lite 8308S
2006 Dodge Ram 1500, V8,
5.7L hemi engine, 4.10 rear axle ratio
2 Siberian Huskies
enblethen
Moses Lake, WA USA
Posted: 06/02/08 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Could be the springs.
Could be bushings in shackles.
Crawl under and get axle and spring manufacturer. Tag should be on curb side end of axles. Write down all information including serial numbers. Go to their website and it should give measurements on spring arcs and distances. If not on website e-mail for them for help.
Bud
Suzuki XL7 pushing Pace Arrow
youroo
waynesville ohio
Posted: 06/02/08 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
1960 stream probably has rubber torque axles. If rubber is bad (new axles)! youroo!!
eubank
Angel Fire, NM, USA
Posted: 06/02/08 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
This is not uncommon for vintage Airstreams, just part and parcel to owning and maintaining a 30 or 40 year old rig.
Go to http://www.AirForums.com, join up, and do a search for axles. Lots of discussion, lots of axle replacement info. You can either have it done, or you can do it yourself; it's not difficult to do.
Lynn
http://forum.aardvarkrv.com/blog/
airstreammama
Wy
Posted: 06/03/08 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
PatSak,
It is our 1960 Airstream. Sadly, so far out of warranty, and so many owners ago...The tires have just died of old age...I just don't want to replace them only to find out on towing and lose an axle.
 > bad axles?
