RV.Net Open Roads Forum: fuzion 403 with Dodge Ram 3500 Mega Cab 6.7 Diesel
Search only in Toy Haulers
 > fuzion 403 with Dodge Ram 3500 Mega Cab 6.7 Diesel
Page of 9
Ran
Wisconsin
Posted: 07/03/08 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
To each his own of course, but isn't going to the Ricksons a bit of overkill in some cases? I mean, the highest drive axle weight I've seen so far (and I scale just about everytime we head out because there's a truckstop on our way out of town) is 6020#. My E-rated GY silent armors are good for 3415# each at 80psi. So, I'm under max weight on those tires by 800 pounds, and usually by more than that. When I load down the TH garage it usually takes another 200# to 400# of the pin, so I generally see drive axle weights at more like 5800#.
I guess what I'm asking is .... at what point are you just throwing money away? Heck, I suppose that I could buy a $15,000 commercial riding mower to cut my half acre lawn too, but my $300 walk behind gets the job done just fine
rcchallenger
La Mirada, California
Posted: 07/04/08 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
Ran,
What are you towing? To tell the truth I haven't crossed the scale with my Raptor. I was worried I wouldn't like the results
My trailer pulls smoother fully loaded than it does empty. Perhaps my pin weight is less than I imagine.
I was just thinking it's better to error on the side of caution.
2005 Ford F350 XLT 4X4 SRW Powerstroke Diesel Firestone Air Bags
2006 Keystone Raptor 3612DS
2006 Yamaha WR450
2006 Yamaha YFZ450
2005 Yamaha TTR230
2006 Kinroad XT250CC Go-Kart
sasha_j
Dumfries, Virginia
Posted: 07/04/08 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Having a truck camper in the PU bed, plus, 500 lbs of trailer on the ball hitch, I have more weight back there than you guys with 5th wheel toyhaulers and weight on pin.
Our Web Site
05 Ford F350 SD 6.0 PSD CC LB 4x4 SRW Lariat, 11500 GVWR, Alum Ricksons, G124 265/70R/19.5/G tires, Airbags
05 Snowriver 8'10" Super Slide w/ 100 W Solar, All Weather, slides
07 Prolite 7.5x14 V Nose Aluminum Toy Trailer Mobile Garage
Ran
Wisconsin
Posted: 07/04/08 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
rcchallenger,
I'm towing a Raptor 3814. My empty pin weight is significantly more than when we have toys in the garage. And...like you, I think it tows better with 'stuff' in the garage. In fact, when we use the TH for camping only, I fill the water tank and take the cargo out of the front compartment and put it in the garage. It tows better with the 'ballast' in the rear. Also, I believe that your pin weight is probably a touch more than mine from the factory because you have a bedroom slide and I don't??
I very good buddy of mine has a 3612 and tows it with a 2003 Dodge Cummins. He loves it!
Ran,
Ran
Wisconsin
Posted: 07/04/08 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah....that makes sense. How much is your drive axle weight when fully loaded and pulling the trailer? (maybe you've already posted it and I missed it....if so, sorry).
pupeperson
Silver Springs, NV
Posted: 07/05/08 01:09am Link  |  Quote  |  Print  |  Notify Moderator
Tex Garcia said: "WOW,
That looks like it could have left the factory like that."
Thanks! Thats the look I was going for. I think the Ricksons or a factory equivalent should be a factory option, along with the air bags, etc. They could market them as 3750's or something. Of course, if they did that they'd probably have to change their dually designations but there are lots of folks like me (and apparently you) that really don't want a DRW for a daily driver.
Just a couple of weeks ago I spent half an hour or so watching 3 city workers trying to get the mini boulders pried out from between their rear duals on a city owned F-550. Finally told them to put a bar between the tires and between the hub and the rock/s and move the truck forward or back to use the ground as one end of a lever, the hub as the fulcrum and the rock as the end to be levered out. It worked, but between the 3 of them they had already wasted over 1 1/2 hours of city time screwing around with it. Of course, I guess they could have just driven on and let it take out somebody's windshield or worse. Guess we should be thankful for small favors, eh?
The point is, dually's, as good as they are, have drawbacks that most folks don't think about and they just aren't the right answer for some applications, even when there's enough weight involved to warrant them.
sasha_j
Dumfries, Virginia
Posted: 07/05/08 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
I heard that
sasha_j
Dumfries, Virginia
Posted: 07/05/08 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
My stock LT275/70R18 Continentals were "E" rated at 3,640 lbs each.
Double that and they slightly exceed the rear axle GAWR of 7,000 lbs.
My truck's weight with camper, fully loaded and wet for trip is close
the edge, but not over:
Front axle: 5,560 lbs
Rear axle: 6,620 lbs
Rear axle when towing: 7,000 lbs and change (depends on toys, extra water, diesel and gas)
I did not want to be at the edge of my ratings with the stock tires
wanted additional safety factor beyond the OEM equipement.
My truck's weight only, with full diesel, one passenger and light
weekend supplies:
Front axle: 4,920 lbs
Rear axle: 3,160 lbs
Gross weight: 8,080 lbs
My truck's weight with camper, fully loaded and wet for trip:
Gross weight: 12,180 lbs
Loaded camper weight alone: 4100 lbs
My ratings:
Front axle GAWR: 6,000 lbs
Rear axle GAWR: 7,000 lbs
GVWR: 11,500 lbs
GCWR: 23,000 lbs
Ran
Wisconsin
Posted: 07/05/08 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
weekend supplies:
My ratings:
GVWR: 11,500 lbs
GCWR: 23,000 lbs
Wow...that's some serious weight! Now I see why you went to the Ricksons. Good move.
DOITHARD
Loxahatchee, FL
Posted: 07/06/08 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
For what its worth...I had a 2004 2500 4x4 Short bed Cummings Larmie Quad SB w/ Toyo AT 33", 18" rims, auto rear airbags, towing a KZ 41' Toyhauler, dry hitch pin wgt 3200# trailer GW 18K #...Truck was great never had a problem, but I didn't feel comfortable in the mtns. Decided to traded in a purchased a 2008 3500 Dually 4x4 6.7 Dsl quad long bed...wow! what a difference. In my opinion if you are border line on towing wgt, traded up...of course if the bgt allows.
2008 Dodge 3500 6.7L DRW LB QC 4x4 Laramie 24k Signature Hitch
2005 KZ New Vision Sportster TH 41'
Honda Rincon 03'
Suz 02' 400Z
Pol 02' Trailblazer 250
10' Inflatable w/ 15hp Merc.
Kayacks 12' & 16'
"DRIVE FASTER MAKE THE ARABS RICHER"
Page of 9
