RV.Net Open Roads Forum: Dinghy Towing: fuse to pull on Equinox Sport
Search only in Dinghy Towing
 > fuse to pull on Equinox Sport
opbart
Overland Park, KS
Posted: 06/02/08 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone set up an Equinox Sport and determined the fuse to pull to turn off odometer. Recently purchased and have set up with Blue Ox base plate, tow bar and Brake buddy. Want to keep battery connected to power Brake Buddy.
skrams
Burlington, Ontario
Posted: 06/02/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Your owners manual should have this information under the dinghy towing section. My Chevy Cobalt owners manual is very clear on which fuse I have to pull.
2007 Four Winds Hurricane 34B (Ford Chassis) Bunkhouse
2007 Chevrolet Cobalt LT (5-speed manual)
SMI Stay-In-Play & Blue-Ox Aventa LX
opbart
Overland Park, KS
Posted: 06/05/08 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Book says to disconnect battery to save power - nothing about odometer. Just want to avoid this
RLS2
Eureka, MO
Posted: 09/09/08 07:51am Link  |  Quote  |  Print  |  Notify Moderator
opbart:
Did you ever get an answer to the battery problem? I am looking at a equinox sport and don't want to disconnect the battery.
RLS2
Rick Jay
Greater Springfield area, MA
Posted: 09/11/08 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Question: What model year Equinox's are you discussing? My understanding is that since 2007 the Equinox is NOT flat-towable. Model year 2006 and older 4WD models were, I thought. The Equinox is a joint venture with Suzuki and was the same basic vehicle as the Suzuki XL-7. The Suzuki XL-7's were no longer flat-towable beginning in model year 2007. The entire vehicle, including the engine/drive train was changed from 2006 to 2007 and became more GM...less Suzuki.
Or am I mistaken?
~Rick
2005 Georgie Boy 3625 DS on a Workhorse W-22 (Class A)
Rick, Gail, 1 girl (12-Angel), 1 girl (7), 2 boys (8 & 5), 1 plump Golden Retriever.
2001 Honda Odyssey with Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
RLS2
Eureka, MO
Posted: 09/11/08 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
I am talking about a 2008 Equinox Sport. I think the Sport is the only one that can be towed.
Rick Jay
Posted: 09/12/08 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Does the owner's manual say that these can be flat-towed? I know the pre-2007 model year XL-7 Suzuki's had a section that clearly detailed the way in which the vehicles could be towed.
If the owner's manual doesn't specify "Recreational Towing" instructions, I'd proceed very cautiously before committing to purchase. You could easily void your drivetrain warranty if the manufacturer doesn't condone the method of towing.
I'm not saying the Equinox Sport isn't towable, but if it's based on the XL-7 I'd be very surprised if it was. If it's based on the Grand Vitara, then I think it's still towable, but only with certain drive trains (4WD, I think).
~Rick
On edit: I checked the Dinghy Towing Guide here for 2008 and didn't see the Equinox listed.
* This post was last edited 09/12/08 05:53pm by Rick Jay *   View edit history
RLS2
Eureka, MO
Posted: 09/12/08 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
It's based on the GM 3.6 V6 and the new 6 speed transmission that is towable. It is only the Equinox SPORT that is towable.
* This post was edited 09/12/08 08:03pm by RLS2 *
mtaylor05
Troy,MI.
Posted: 09/13/08 11:54am Link  |  Quote  |  Print  |  Notify Moderator
Remove the batt1 fuse from the engine compartment fuse block and you should be fine.
The Traveling Taylor's
2004 Infinity 36A
2008 Chevy HHR toad/brake buddy
RLS2
Eureka, MO
Posted: 09/14/08 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
mtaylor05
Where did you find this information? Is it in the owners manual?
