TPLynch
Arizona
Who cares what time it is when you're camping!!!!!!
2007 Chevy 2500HD 6.0L 4.10
2008 Jayco Jayflight 29BHS
JTCR
Central Mass
I used a hook that screwed in to wood. I tired a 3M hook but found clock on floor in pieces one morning. I think the changes in temperature in TT is to much for the sticky tape.
2004 GMC 1500 4x4 Extended cab short bed 5.3 3.73
2007.5 Jayco 328RLS
Joyce in NY
NY
We've had three trailers that came with clocks. They were attached to the wall only by heavy duty velcro and never once fell off the wall. We used the trailers long enough that batteries were replaced, and the clock was stuck back on the wall. We do some heavy duty traveling -- one clock survived a coast-to-coast trip and never moved!
lat471
Lebanon, PA
Same type of clock. Velcro. No holes for me please.
07 Cameo LXI F35FD3
R Taj-We-Haul
skipnchar
Topeka Kansas USA
We have a very similar clock and it hangs very nicely on pressure sensitive velcro hooks all the time we had it hanging near the dining table (right over the axles) but we moved it to the back of the trailer and STILL no problem with the hooks but the clock itself sometimes bounces off of the hook so we now take it down when traveling.
pilgrim's progress
Beautiful southeastern Ohio
3M items are GREAT!! We've used them for pictures, towels, bathrobes, etc... They are excellant and have never lost anything. If they are not up straight, we take it down and put it up again. They are removable so easily and leave no marks of any kind. No matter the cost, they are worth it! We've found them at Menards, Lowe's, CVS and they're probably in lots of places.
___________________________________________
2007 25' Airstream International SS OB
2004 Nissan Armada
Equalizer hitch
Prodigy brake controls
"It's better to keep your mouth shut and thought a fool
Than to open it and remove all doubt."
Hgarnerno1
Tyler, Texas USA
Just be sure to check the clock at night to see if it is noisy. We put on of the el cheapo ones up and it kept us awake all night. Finally threw it in the trash can..
Howard, USN Ret
2000 Ford Excursion,V10, Limited
2003 Terry 27H. Super Slide
Anthony21403
Arkansas
I have my atomic clock hung on a cupboard door with the 3M Command velcro strips. Stays there well and have also used the same strips to hang picture frames in the TT. When I travel, I just take the items down and reattach them when I am set up.
TSG Tony, USAF, 17 years
johnthecamper
Grapevine, Texas
We have a similar round clock from Walmart. Used Velcro in 3 positions 12, 4 and 8 oclock. Has traveled many miles without problem. Easy to takeoff for battery changes.
Threedognight
Ridgefield, Washington
Well, I've spent about an hour googling the kind of wall mount bracket system that our clock has and can't find it for you. Basically there is a bracket that attaches to the wall and the battery movement on the back of the clock just slides right into it. I even contacted the mfr. of our trailer (Crossroads RV) to see if they could get me info on that system. I guess the next best thing is sticky Velcro.
