iguana07
Ventura, CA. USA
The dealer is offering us a choice for the TV antenna the round omnidirectional no crank version or the crank up style, not much difference in price. The salesperson says the crank up works better? The round one looks nicer in our opinion.
Which one should we choose? We currently have a crank up in our class A and seems to work fine. All feed back appreciated.
Thanks
Chuck
Chuck/Sandy/&Maya the Sheltie & Kharma the Mutt
2002 Rexhall Roseair 39'DP
Toads = 1967 VW Bug,1976 CJ5 or HHR
THE BEST IS YET TO COME!
SCVJeff
Santa Clarita, CA.
Omni: BAD.... VERY BAD....! There is a reason that all residential and commercial antennas are directional. Even Rabbit Ears are directional by virtue of user twist. Omni's obviously have no way to trim out multi-path short of moving the vehicle. In analog it looks like poop.. in digital the picture just goes away.
Jeff - WA6EQU
MNtundraRet
Bloomington, MN
You will need the Winegard antenna. All Winegard antennas, RV or home-type are considered best for digital signals.
Mark
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
lv2rom
Kansas City, Missouri
Unless you want to be spinning your vehicle around in your campsite to get reception for the channel you want to watch...get the crank up.....Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
Wherever I happen to park
There are two round antennas, one is omni the other not
The Batwing outperforms them, no question there at all (Crank up)
What others have said about Omni... They may work in some cases.. but on the list of things you won't be happy with.. They are right close to the top.
The Crank up is much better
dons2346
Sioux Falls, SD, formerly of So. CA
Crank up Wineguard batwing. The best antenna for an rv.
TXiceman
(Near) Houston,TX
My brother has a round Omni directional antenna and said he could get better reception with a piece of wire and a pie pan.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
iguana07
Ventura, CA. USA
Thanks!!!!!!!!!!!!
We will go with the crank up.
MELM
GA
Moving to Technology Corner from Tech Issues.
kneal44
EAST CENTRAL TEXAS
i was camping two weeks ago on south padre national seashore many miles from corpus christi and i got great reception with the crankup Sensor antenna. but the salt in the air corroded the connector at the base and to make a long story short caused me lots of anguish fixing the problem... always pack every connection with silicone grease that will keep out moisture and corrosion.
when u play in the sand .... you can get stuck
9-24-08 corpus christi padre island texas. wrecker had to haul me out!
'92 dp 5.9 cummins 190 hp....8mpg yuck!
