RV.Net Open Roads Forum: Travel Trailers: Coachman Micro Propane quick connect
 > Coachman Micro Propane quick connect
DeltonaDug
Posted: 06/03/08 06:59am Link  |  Quote  |  Print  |  Notify Moderator
My coachman Micro came with a propane quick connect on the side for a grill. Coachman does not provide a hose, and trying to find a hose or adaptor was proving to be impossible. NO ONE has a quick connect to a disposable bottle regulator in the Orlando area. Finally I found the proper hose at http://www.mbsturgis.com/Camping%20Stoves.htm and it was only $20 for a 5' hose or $24 for a 10'. Just wanted to post this because I have gone crazy for 2 days looking and maybe this will help someone else find what they need.
skipnchar
Topeka Kansas USA
Posted: 06/03/08 09:16am Link  |  Quote  |  Print  |  Notify Moderator
So you're trying to fill a disposable bottle from your on board propane connection?
Anthony21403
Arkansas
Posted: 06/03/08 09:57am Link  |  Quote  |  Print  |  Notify Moderator
i think what he is trying to do is use the quick connect to feed to a stove or grill that is usually used with the small disposable bottles. You know, like the newer Coleman stoves use.
TSG Tony, USAF, 17 years
GHMJR
Central New York
Posted: 06/03/08 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for the post I was looking all over for the exact same thing
naturist
Lynchburg, VA
Posted: 06/03/08 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
I assume your Coachmen Micro is the same as mine in this regard: you will find that the low-pressure propane supplied from that quick-connect fitting will not work to fuel an "standard" unit, either grill, lantern, or heater, which requires a high-pressure fuel tank or hose. You may have succeeded in plumbing a highly creative and completely non-functional Rube Goldberg setup here.
The special gas grill that connection is supposed to feed is designed for the purpose. It won't work with a high-pressure feed.
But hey, best of luck with it, and if you get it working be sure to let us know how.
kirk37r
Millville, New Jersey
Posted: 06/03/08 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry but as Naturist stated. A Coleman propane product will not work from your disconnect on the TT It is regulated pressure fed from the 2 stage regulator at your tanks. see if you can send it back, if so what I would suggest would be A separate Propane tank and the hose that fits it then connects to the regulator for the grill you are using.
We carry A 11 LB tank to run our Roadtrip grills and it works great. sure is cheaper than the small cylinders.
Happy Camping!!!
2007 Wilderness Yukon 300RLS TT
2007 Silverado 1500 5.3 4X4 Extended Cab, Z71 & Z85
2008 Tahoe LS
Reese WDH W/Dual Cam, Prodigy Brake controller
Putnam XDR
Carol & Kirk Sometimes 3 Grandkids
silvercrew
Brooks Alberta
Posted: 06/05/08 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
My dad run into the same thing with his motorhome so he moved the fitting to before the regulator. You can't go through 2 regulators and make it work. I know it would be a little more work but you could install a tee and a small pipe before the regulator on your trailer and still use the part you bought. When I did mine I got a coleman road trip XLE grill and removed the regulator that came with the grill and hooked the hose straight to the grill.
2004 Expedition EB 5.4l hd tow pack
2005 Triple E Topaz LE T274XL
Prodigy brake control
Equal-i-zer hitch
Cipa mirror extensions
Proforce gen set
Colman LXE grill
