rlh6805
Michigan
Hello all.
For all those who have Ford V10's in their TV's, or motorhomes for that matter, how many have had to fix broken exhaust manifold bolts. This is a known issue with these motors and there are quite a few posts on ford-trucks.com regarding this. My 2001 Ex has a few broken off on both sides and the correct fix it to replace all 20 (10 on each side). Problem is that the dealer wants $1,000 to do this. Has anyone had luck taking it to a local exhaust shop for the work?
Rob and Cindy in Michigan
2004 Prowler Regal
2001 Ford Excursion V10 4x4
Tasha, Deanna (RIP), and Abby (our dogs)
rob85546
Hot arizona
Man, I thought they fixed that problem with the V-10.. I know the 460 had major problems with that..
rlh6805 wrote: Hello all.
2007 GMC DURAMAX,LBZ,4 by Crew, Allison
Magnaflow Turbo Back Exhaust
Predator Tuner
18by9 Helo's on BFG's
5year old boy
3 year old baby girl
Sea ray boat
Wilderness 5th wheel
SandRail
HD WideGlide
FORD Expediton
honda Eu3000
samsontdog
Sac. Ca summer, Yuma Az winter
I am on the 3rd vehicle with a V10 and no problems at all. The current V10 has 52K miles on it
samsontdog
rlh6805
Michigan
samsontdog wrote: I am on the 3rd vehicle with a V10 and no problems at all. The current V10 has 52K miles on it
You don't drive in winter conditions w/salt on the road then. This is a huge issue in the northern states.
carringb
Corvallis, OR
I had one stud break, and another nut fall off (stud was fine). Neither caused an exhaust leak.
When I had the Banks PowerPack installed, a 2nd stud broke when pulling the stock manifolds.
The shop (Ed's Muffler's... local to Portland only I'm sure) charged me $75 each broken stud, so $150 total.
I'd try a local shop, and just replace the broken ones.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, 230,000+ miles
Had: Weekend Warrior 41' FSW (still looking for its replacement)
rlh6805
Michigan
carringb wrote: I had one stud break, and another nut fall off (stud was fine). Neither caused an exhaust leak.
I'd try a local shop, and just replace the broken ones. If you really want to replace all.
Yea, I've got about six broken between both sides. Most are just the nut broken off the stud that I can tell. I can see one that looks to be the stud snapped off at the head (hard to tell with the manifolds still on). I do want all of them replaced though.
ol' yeller
Federal Way, WA
I just had mine done at a local shop. My truck had 83K on it. WA does not use salt on the road. The problem is a poor design, too small of studs and a big long exhaust manifold that gets hot and cools so it expands and contracts. I thought I only had 1 broken. 6 came out in 1 piece, 4 were broken in the head, and 10 came out in pieces. It cost me $1,000 and it was well worth it. The nuts will snap off as they are compromised where they contact the manifold.
1999 F250 XLT Superduty Supercab 2WD, V10 pulling a 2006 Keystone Cougar 243 RKS
Oh yeah, the wife & Beagle come along too!
coryrhonda
Minnesota
fix them all the time. the real problem is the manifolds warp snf bust the studs. The studs almost always come out easy and I mill the manifolds straight again and install no gasket if the surfaces look clean or copper gaskets it they look rough on the head. the prolem is heat transfer from the manifold and the head. non 100% metal gaskets insulate heat between the two and they expand at different rates, and cold water hitting a hot manifold doesn't help the warping
DoCPooF
NY
I ended up replacing 7 total.
3 on one side and 4 on the other.
My local mechanic charged me about $300/side with parts and labor.
Ford even sells a kit because of this problem. Most of the time they can back them out with a EZ out. They are only torqued down to like 24 ft.lbs. The other trick is to tack weld a small nut onto the shaft of the bolt and then back them out. If they end up needing to drill them out Ford sells a kit with sleeves and stainless steel bolts to fix the problem. (but they won't admit there is a problem)
Well known problem with the early 2000's.
I just sent my 01 F250 v10 up the road for a 08 F350.
Good luck.
2001 Ford F-250 with V-10, off road and towing package, 4:11 rear axle
2005 29' ForestRiver Salem LE
2005 Yamaha Rhino Camo w/rear roll cage, BRP CDI, LCD dash, ITP C's on 26" Mud lites
1 wife and 2 children
richk88
birdsboro pa.
I had about six broken studs between the two sides,I removed both manifolds and got all the studs out easily,thank god they are stainless,cleaned all surfaces good,put new gaskets in and replaced the studs with grade 8 bolts coated with nickel antisieze.
05 sunline 267 sr(younger family with a sunline almost unheard of)
2001 F-250 lariat 4x4 supercab shortbed automatic V-10 4:30LS
1200# drawtite hitch friction sway control,prodigy
