RV.Net Open Roads Forum: Using 30 amp service on a 50 amp Fifth Wheel
Search only in Toy Haulers
 > Using 30 amp service on a 50 amp Fifth Wheel
JFJ
TN
Posted: 06/03/08 08:04am Link  |  Quote  |  Print  |  Notify Moderator
This weekend I am going to be at a campground that only has 30 amp service. My 5er requires 50 amp and has two A/Cs, microwave, etc. They said that as long as I didn't run BOTH A/Cs and a lot of other stuff, I should be fine. I am skeptical, but wanted to get some veteran feedback.
2007 Dodge Megacab 2500 4X4 SRW
6.7 Cummins w/6 Speed Auto
2005 Raptor 3612ds
Pacbrake Air Bags
Prodigy Brake Controller
Pullrite Superglide 24K
ScottG
Bothell Wa.
Posted: 06/03/08 08:10am Link  |  Quote  |  Print  |  Notify Moderator
"They" are correct (as usual ). As long as you have an adapter you'll be ok.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
Sinterior
BC Canada
Posted: 06/03/08 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Hi, my fiver is 50amp, and using one A/C on 30 amp is fine, even using the M/W at the same time, just make sure you have the 30amp male/50amp female adapter.
Jack_Diane_Freedom
Lindsay Ont, and Gulf Coast Florida
Posted: 06/03/08 08:24am Link  |  Quote  |  Print  |  Notify Moderator
We are currently in a 30 amp park with a 50 amp trailer. I just put the fridge and water heater on gas and carry on. I do not think you will be able to run two A/C with 30 amp.
CrazyTed
Hoollieville #214
Posted: 06/03/08 08:42am Link  |  Quote  |  Print  |  Notify Moderator
I have a 50AMP trailer that I run off my 30AMP generator all the time. I cannot run both A/C's at the same time as the living room A/C is a 15,000 unit. If that one is running, I can't use the microwave or anything else. With just the bedroom 13,500 A/C running I can us whatever electric I want to.
CrazyTed
www.CrazyTed.us
Va Bch, VA
2006 KTM 450 XC
1997 Triumph Tiger 900
2005 Chevy 2500HD 4X4
2008 CrossRoads CrossTerrain TF36DS
smkettner
Posted: 06/03/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
You can run two high amp appliances at one time. Put the fridge and water heat on propane. Remember the converter may draw a lot of power for the first couple hours if your battery is low.
DuneJunkie
Rohnert Park, CA.
Posted: 06/03/08 09:40am Link  |  Quote  |  Print  |  Notify Moderator
dont run both a/c's and you will bw fine.
2005 Chevy 2500HD 4x4 CC Duramax/Allison, with 18K SuperGlide Hitch
2008 385 Fleetwood Gearbox
2005 Yamaha YFZ 450
2002 Honda 400ex
kampinglovers
Posted: 06/03/08 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
We have been using 30amp with our 50 amp trailer for 6 months.....haven't had a problem. You just have to manage your electricity usage. I always turn off the A/C when using the microwave or my hair dryer. What I have found that really throws everything off is our hot water heater.
DH, me and our 3.5 lb Yorkie "Missy"
2006 Dodge 1Ton
2008 KZ New Vision 41RLN
2005 HD Road King Custom
socalhd
HB
Posted: 06/03/08 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Contrary to the post above, I ran my 2 A/C's on 30 amps (15k & 13.5k) at the same time for 24 hrs a day for 4 days straight w/ no problems in Havasu a few weeks back. Fridge was on propane. Also, 5 other trailer in our group did as well. This was at Cattail Cove Campground, AZ.
06 GMC 2500HD SB/CC 4X4 D/A
09 34LKSG Eclipse Stellar 5'er
robertmeier
texas
Posted: 06/03/08 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
i got a box from camper world that uses the 30 amp and the 15 amp plugs at a cg and gives me 45 amps. with this i can run almost everthing, even my hot water. the only problem is my dw forgets to turn off the air when she dries her hair. that means i have to get out of bed and go set the breaker quite often.
full time
both mid 50's semi-retired
35 ft kountry star fw
f250 7.3 psd with custom exhaust and intake and superchip
sorry about the lack of capital letters. programmer by trade. we never use caps.
