RV.Net Open Roads Forum: Fifth-Wheels: Fan out of balance?
 > Fan out of balance?
Vroadracer
Dickson, TN
Posted: 06/03/08 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
The electric ceiling fan in our 2005 Caqrdinal 37RL is out of balance. The fan appears to have some type of ball and socket mount to the ceiling. When you turn the fan on, it starts to vibrate to the point that you have to turn it off.
We bought our unit in the winter and have never tried to use the fan before. We are not sure what is wrong. Does anyone have any experience with a similar problem? If so how do you resolve it.
Vroadracer
Ninebell
Bardstown,Ky
Posted: 06/03/08 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
The ball and socket type mounting is used so that the fan can seek it center and not vibrate. You might try pushing up on the entire fan gently to off seat the ball from the socket and then let it down.They are made of hard plastic and sometimes setting in the heat of the trailer over long periods of time they get stuck and won't move to find there center(friction)or try alittle furniture polish on the ball to help it move.Good luck
Ninebell,the Wife,and Ginger the Shiz-zhu
2008 F-450 Lariat PSD,DRW,CC,LB,4X4
2007 Jayco Designer 34RLQS.
My Photo's
Larry202br
Olathe, Ks
Posted: 06/03/08 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
You probably need a blade balancing kit. Here's one way to balance the fan. http://www.rd.com/familyhandyman/content/19664/
2006 Open Road 316 RLDS-5
2004 F-250 Diesel, short bed, SRW, Crew cab, 3.73 auto.
jason_rving
North Georgia
Posted: 06/03/08 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, make sure it is seated in the ball and socket joint. Also there is no need to buy a balancing kit. Tape a few pennies to the top of a blade and test. If it balances good, if not, move the pennies to the next blade until it balances.
Jason and family
2004 Cedar Creek 31LBHBS
2004 2500HD Silverado CC LT LLY Duramax/Allison 4x4
48 Gal Aux Fuel Tank - 74 total gal cap.
Husky 16K, Kipor 3500ti Generator
Prodigy, Timbrens, 285 Goodyears, Rhino Lined,
Cobra 75WXST with Firestik
FlaCracker
Posted: 06/03/08 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure that all of the blade tips "track" within the same plane. Tips that are high or low will cause an oscillation or act like they are unbalanced. Also make sure all the blade to hub screws are tight.
sljkansas
Miami Co. Kansas
Posted: 06/03/08 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
If it needs balanced, get some 1/2 washers, and blue masking tape. Add a washer to one blade, and see if it gets better, if not try another blade. Once you find the blade that is out, add more washers until it's spinning smoothly.
I have $1.25 in quarters on a fan on my wife's cousins fan in her house, smooth spinning for 5 years.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter in College
Miami CO. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
abskws
Pamplin, Virginia
Posted: 06/03/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with the 1/2 inch washer thing but you could use pennies. You may not have to add but one or two. Start putting them on up next to the motor and keep sliding them towards the tip of the fan. The futher out you tape them, the more "out of balance" they correct. It's a trial and error thing. Good Luck!
Allen
sch911
Rochester Hills, MI
Posted: 06/03/08 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
If you have access to a simple scale it's pretty easy to take the blades off and weigh them. Once you have them all weighing the same your problem should be solved.....
2003 Damon Challenger 348 Class A - Triton V10
Posted by Macintosh
shadoow
South Texas
Posted: 06/03/08 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
just one more thing on the ball & socket setup. The ball fits into the socket only one way & should not rotate. Make sure it's seated properly
KZ 33P Toyhauler
2008 GMC 2500HD D/A
2006 Ultraclassic
1978 FLH
