RV.Net Open Roads Forum: General RVing Issues: Exterior Storage Compartment Add Ons
 > Exterior Storage Compartment Add Ons
JeffBett
San Diego
Posted: 06/03/08 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know of anyplace to get or know of any add on storage compartments that would bolt on under a TT between the frame and the outside edge of the TT. It would be a handy place to add storage for things like the sewer & water stuff, leveling items, air compressor type stuff. Basically like adding class A style basement storage to a TT.
Jeff, Lori, Capri & Jacob
08 Aerolite 21QS
01 Ford F150 Supercrew
downtheroad
Puget Sound
Posted: 06/03/08 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have the clearance? What about going over driveways and slopes like into fuel stations?
Maybe I'm not picturing what you are proposing.
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Pic
Reese Dual Cam HP
javaseuf
Southern Cal
Posted: 06/03/08 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
I was toying with the same idea to use to slide-in my blue tote-tank.
We are speaking of behind the skirt that continues past the floor line. I have about 11" before the bottom of the frame.
I'll be watching for some ideas as well.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
JeffBett
San Diego
Posted: 06/03/08 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
The clearance would basically be the same as the frame. I am talking about the space under the belly of a TT from the outside edge in to the frame. Even if a TT has an enclosed underbelly, this "outer" underbelly is mostly unused and easily accessible. They make undercarriage tool/storage boxes for flatbed pickups and semis, but they would be to tall.
AO_hitech
SF Bay Area
Posted: 06/03/08 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
I, too, would eb interested if any such thing exists...
NHguy
NH
Posted: 06/03/08 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
What color would you like? Wood, fiberglass, or metal? How deep, long and high? Graphics or plain. You can have anything you want for a price!
But more seriously, good idea. I think I'd try to keep them toward the wheels and therefore away from the ends. I think they'd suffer fewer contact damage problems there.
If doing a deluxe job they could have lighting and/or drawers. One problem is frames are not very high. But if the TT was far enough from the ground you could perhaps go 5 or 6" in height.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
Chuck Roder
High Springs, FL
Posted: 06/03/08 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
I have thought about the same thing. I have found some things that looked like they would work (designed for a truck) but the prices was out of my line $500+ made in stainless steel. Some type of poly material would be fine, and a better $, but I have not found any.
Chuck Roder & Family
'07 Surveyor SV-235RS
'03 Chevy TrailBlazer EXT LT V8
High Springs, FL.
Our Pictures
javaseuf
Southern Cal
Posted: 06/04/08 09:49am Link  |  Quote  |  Print  |  Notify Moderator
I am going to see if I can find some type of blown/molded-plastic bins that I can mate-up with a radius corner baggage compartment door and sandwich the skirt between the two. With the correct bracing, as well as a support in the rear to the frame or floor, it should work for the storage lighter items.
Match the trailer paint color and we should be good to go.
Jnbaun
Ridley, PA
Posted: 06/04/08 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately I don't have pictures but I built a couple for my old TT. I used some pressure treated 1x4's and built 2 boxes within the frame rails. I used one box to hold the weight bars from the hitch and the other to hold some small boards to put under the tongue jack and stabilizers. I painted them to match the frame and installed barrel style locks to keep everything secure. Like a previous poster stated, I mounted them up front to reduce the chance of them hitting the ground. These were not weather proof, but for what I wanted they did the job and were inexpensive to build.
John
Wife - Renee and 2 boys ages 12 and 7
AO_hitech
SF Bay Area
Posted: 06/04/08 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure to let the rest of us know if you find something that works. That is the same thing I'd like to do.
