RV.Net Open Roads Forum: How to Measure Your RV 12V Power Usage?
 > How to Measure Your RV 12V Power Usage?
JQgolf
Sacramento, Calif
Posted: 06/03/08 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Have had our first travel trailer for 5 mos and just went on 1st non hookup trip, 4 nights. We have two 12v group 24 batteries which I charged for about 24 hrs before leaving. Since it was colder at Lake Tahoe at 6500' than normal, we had weather in the 40-50's daytime and right at freezing each night. We ran the heater for 10-15 min before bed and thru-out the night at the same rate. When we checked the batteries on the monitor the next morning, we were down to 1/3. I charged daily with Honda EU 2000, at 8 amps for up to 4 hrs per day for rest of the weekend and we really conserved our usage, mainly for water pump, furnace, one light at a time, water heater. Even made perc coffee.
I want to do an inventory of what each thing we have in the trailer uses for 12v amps, but not sure how to apply the numbers I find? Besides the amps per hour ratings, do I need to add lot more for coming on and off like water heater (electric start for gas), or furnace where it came on for 10 min every hour or so. What are the hidden things you have to add or the inefficiencies of the converter, charger, generator?
Just seems like our 140-170 amp hours should not have depleted so much each day. We have 3 stage converter, two small slides which I put in or out with truck hooked up and running, Electric jack but also use only with truck running.
Could use some help to do right. Thanks.
Hurricaner
Hurricane Utah
Posted: 06/03/08 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
That's your first mistake. The Honda was never intended to be a battery charger. So lets start with the basics. What converter do you have?
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
oujoker
Monterey, CA
Posted: 06/03/08 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
The current consumed by spark generators for furnace, etc are negligible compared to current consuming devices (lights, 12 appliances, inverter, etc) and can be ignored. If you want to get really exact, you can measure each load with a meter, but keep in mind not all things will be on for the same amount of time and at the same time.
2007 Dutchman Express 31 Class C
2006 Centurion Elite V C4, Air Warrior
WaltinColo
Colorado Springs, Colorado
Posted: 06/03/08 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
A Trimetric 2020 battery monitor will tell you exactly whats being pulled out of the battery in real time. Ive gone around the camper turning things on and off while looking at it to know where the 'power pigs' are.
Also, 140-170 amp hours? Is that total? If so, you really only have about half of that since you never want to take your batteries down more then half way...
'06 AWD V6 Saturn Vue
'05 Jayco 1207
'07 22ft SunTracker Regency pontoon
Me, the wife, and the little guy....
...oh, and 1 loving, ready to go camping anytime, Black Lab
DAYS CAMPED SINCE PUP PURCHASE: 112
BEERS DRANK: 2374
Johnofbham
Birmingham, Alabama
Posted: 06/03/08 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
My furnace will really suck my battery down overnight so I turn set point down to 50 at night and get under my down comforter. I also adjusted my thermostat to it doesn't come on as often - i.e. bigger temp increase when does comes on.
Are the batteries in good condition. If not you won't be able to charge them up fully.
You said you charge the at 8 amps. Is that 12 volts to the battery. You should be able to charge them at a C/10 rate during bulk charging or 14 to 17 amps.
You mention a monitor. Are you talking about a Link 10 or Trimetric type.
You might consider a small catalytic heater to cut down on the furnace cycling.
You could also turn the water heater off at night if it is using much current to start.
AlanB
Sierra Vista, AZ
Batteries have lowered capacity in cold environments. It also sounds like you were recharging them long enough from the generator. 8 Amps X 4 hours = 32 amphours. It would have to run over 17 hours if they were depleted. Your converter could probably do a higher rate.
To measure actual consumption, you might try the fuse block. Remove the fuse for the circuit you want to measure and connect an ampmeter in place of the fuse. Do this on each circuit. Be sure to use an ampmeter with sufficient range so it does not get damaged.
AlanB
2002 Holiday Rambler Imperial 40PKDD Cummins ISL
smkettner
Posted: 06/03/08 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
This is what you should have used to charge the battery not the 12 volt generator output. The converter probably charges with 45 to 70 amps.
8 amps x 4 hours is only 32 amp/hrs per day replaced. Also you need to have econo throttle off to even get 8 amps. Anyway, plug the RV in direct and let the converter do the charging.
The furnace takes 7 to 10 amps from the battery to operate when the blower is on. I put the thermostat down to 55/60 at night and pack on the blankets.
It would be a good idea to spend $20 on a digital volt meter from sears or your local hardware store to monitor charging voltage and better monitor voltage as the battery is depleted.
A battery monitor is great and will greatly improve the energy management. However it does not provide more power. I use a digital volt meter or the wall indicator to know when to turn on the generator and an amp meter to tell when to turn it off.
Wayne Dohnal
Banks, OR.
Posted: 06/03/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
FYI, this is what the devices in my 20003 Cougar drew. I think most of the current generation devices are similar to this. I assumed about a 50% duty cycle for the fridge. I don't think a clamp-on dc ammeter will give highly accurate readings. If you're at all inclined to install a full-time ammeter, I highly recommend it. Besides measuring loads, it lets you know what the converter is doing, and lets you easily see if something you don't know about is turned on.
DC LOADS (amps)
static 0.1 (propane detector)
refrig 0.36 gas valve on, 0.1 idle auto, 0.05 idle gas only
water pump 4-6
bright double light 2.6
single amber light 1.2
2x scare lights 4.2
outside single light 1.2
range hood fan 1.7
range hood light 1.0
bath fan 1.4
maxxFan 1.4 / 2.3 / 3.7
heater 6.5-7
radio ~1.0A radio or CD on, 0.05A off with ignition on, nil with ignition off
tank heaters 12A (specs., not measured)
water heater, on gas, electronics 0.3, gas valve 0.5. No draw unless thermostat triggered.
landing gear 15A extend, 8A retract
slide extension 14A extend, 14A retract, >20A stalled
2009 Fleetwood Icon 24A
LinkPro battery monitor
EU2000i generator
ScottG
Bothell Wa.
Posted: 06/03/08 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, good info Wayne. Can you tell what brand and size of furnace you have?
Thanks,
Scott
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
Hurricaner
Hurricane Utah
Posted: 06/03/08 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
None of you rocket scientist find a problem with this>??????
Sam
