RV.Net Open Roads Forum: Tech Issues: Battery Not Charging
 > Battery Not Charging
aahlers
Vancouver, BC
Posted: 06/03/08 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
We went camping for the first time this season a few weeks ago. A few days before we left we put the battery back in (as we had brought in the house for the winter) and plugged it into the house electrical assuming it would charge all up. We noticed when we went to leave the Refrigerator would not switch over to gas. Not a big deal as we were not going far. Then same thing on the way back. We also noticed after we unhooked the electrical from the campground the battery showed dead. We replaced the battery last summer with a middle of the road RV Battery. After reading someones elses post asking some questions on Converters I was wondering if that could be our problem. I have left it plugged in since we have been back (2 weeks now) and I unplugged it the other day and the battery still shows dead. What do you think the problem is? If it is a converter are they hard to change yourself? Thanks for your help!
2006 Dodge Ram 3500 Megacab
2005 Areolite Cub 23BH
plascell
Lynchburg, VA
Posted: 06/03/08 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a battery disconnect switch? Be sure it is ON. If battery has been DEAD for weeks, it may be too far gone. If you have an external charger, I would hook it up to charge that way and see if it recovers to use.
Pete W4WWQ DX70 IC-2800 Smartire X-10 camera
2006 Chevy 3500 CC LB 4WD DRW Duramax auto-6
2003 Cardinal 29WB LX EU3000is Roto-Choks 300W from www.amsolar.com
Fisherman
Angus, Ontario, Canada
Posted: 06/03/08 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Going to make an assumption(which can be bad), did you just take the battery out, put it in the house and then expect it to awaken bright eyed and bushy tailed for you many months later. Check the fluid level? Do any over winter maintenance charging? I hope so. Are the connections clean and tight and not backwards?
scanlonj
Worcester, MA.
Posted: 06/03/08 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
How about the fuse on the charging wire, there should be a 30 amp fuse close to the battery, if it is bad your battery will not charge.
Jim & Sylvia
Two sons in college
Two Dogs
2001 Ford Expedition
2000 Palamino Stampede 21-SDSL
