RV.Net Open Roads Forum: Travel Trailers: wheel bearings
 > wheel bearings
Snake Wiley
North Georgia
Posted: 06/04/08 12:44am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2007 flaggstaff with mayby 1500 miles. my question is when do i need to repack the wheel bearings?
SteveRankin
Sequim, WA
Posted: 06/04/08 02:06am Link  |  Quote  |  Print  |  Notify Moderator
Read your owner's manual. Most manufacturers recommend servicing the wheel bearings annually--unless you have NeverLube bearings.
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
2009 Arctic Fox 29V
2005 Chevy 2500HD Duramax 4X4 Crewcab
Hensley Hitch
TruControl Brake Controller
Our Beaver Technical page
Wildlife rescue at the Northwest Raptor Center
mpfireman
Cook County Il
Posted: 06/04/08 05:24am Link  |  Quote  |  Print  |  Notify Moderator
You should check them now. My first trailers wheels were not packed correctly when NEW, thus when I checked them after the first year. I found two of the wheels dry, and the bearings shot. So check all of your wheels, this way you will have a base or starting point for further service.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
tnt4utvols
Tennessee
Posted: 06/04/08 06:40am Link  |  Quote  |  Print  |  Notify Moderator
I would give them a look now. Trailers nowadays save money on everything possible, including the bearings. I would pull, clean, inspect, and pack with good grease and new seals. < 2 hours time and $10 - it's worth it.
Also, a good habit to get into is taking the temperature of your hubs and wheels when you stop for fuel, or arrive at your destination. A variation in temperature will be an early warning on either the bearing, or an over-worked brake drum.
GO BIG ORANGE!!!
Topsail Hill Cult Member
Topsail Hill Site Photos
Topsail Area Attractions
smkettner
Posted: 06/04/08 09:33am Link  |  Quote  |  Print  |  Notify Moderator
If they were done properly they are fine. However the only way to know if they were done properly is to remove, clean and inspect. I waited two years and 5000 miles and found one was installed too tight and needed replacement. Manufacturers generally recommend once a year. I plan to wait two to three years before I repack again. I do carry spares just in case.
kraushad
Eastern Panhandle, WV
Posted: 06/04/08 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Check for EZ lube hubs if they are Dexters, you can sometimes lube them from the outside - still never hurts to pull the hubs and check.
My book says annually I believe.
Dirk
Myself (34), my Wife(32), and "The Boy"(3)
06 GMC Sierra 1500 Crew Cab, 5.3L V8, 3.42rear
05 30QBSS Trail-Cruiser, Prodigy BC, Reese Dual Cam W/D
wrenchbender
Phx
Posted: 06/04/08 11:55am Link  |  Quote  |  Print  |  Notify Moderator
My advice,repack and survey.If with 1500 miles all looks good, you now have a guide if they are in bad shape than a repack sooner will be the norm.
jmadre
Elizabeth City, NC
Posted: 06/04/08 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
Check them now and you can tow with (more) confidence. It's a great way to get to know your trailer, too.
I bought a used (1994) trailer last October and I know we're not talking about the same thing as a new trailer, but I found a damaged bearing that I replaced while I was cleaning out the black, burnt grease.
When I got to the other side I found a brake shoe that had been rubbing the drum because the retainer spring had fallen off and was in three pieces in the brake assembly.
The previous owners had upgraded to a larger TT after owning this one for 1 1/2 years and had done some great upgrades and repairs. With the wear on the brake shoe I don't see how any brake or bearing maintenance could have been done in that year and a half.
Check 'em now. They're a LOT easier to fix in the driveway than on the side of the highway.
1994 Coachman Catalina 280RK behind a 2007 Chevrolet Silverado 2500HD 6.0L + Equalizer 10,000# + Prodigy brake controller
handye9
Park City, IL 60085
Posted: 06/04/08 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
06 Flagstaff here. It also, has low milage. I pulled mine and inspected just because the manual recommended it. Good thing. One of them was a little short on grease. Not dry and the bearing was fine, however, it was a burnt bearing waiting to happen. Don't know about 07's, but, 06 Flagstaff doesn't have EZ-lube Dexters.
Did the repacking myself, I know they are ready for the road.
08 F250 Crewcab 4X4 Short bed
06 Flagstaff 831QBSS
Wife and I
Buddy the Beagle
USN MCPO (E9) Retired (active duty 1973 - 1995)
Check out my mods
 > wheel bearings
