RV.Net Open Roads Forum: Towing: Ford Superduty OEM hitch
Search only in Towing
Open Roads Forum  >  Towing
 > Ford Superduty OEM hitch
AGnGG
Wisconsin
Posted: 06/04/08 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Just curious if anyone has had any failure issues with the Ford OEM receiver hitches, particularly the 2008 versions? I have a Luverne cushioning receiver that I need to remove and rebuild but since I don't have a OEM receiver I was checking with some salvage yards and found some new 2008 "take-off" hitches. Should be able to pick one up for less that $100. This will give me some time to get parts and rebuild my Luverne.
esquaredg
Houston, TX
Posted: 06/04/08 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Years ago I picked up a "near new" receiver hitch from a U-Haul dealer. OEM for my suburban. They said the guy just wanted a different hitch. Might check with those that install hitches.
Eric
JayflightG2
Vancouver
Posted: 06/04/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Only towed a few times for short distances so far, but no problems yet
2008 F350 Super Crew Lariat PSD
2008 Jayco Jayflight G2 29FBS
1200 lb Draw-Tite Trunnion WDH/DC
BrokenElbow
Valencia, CA
Posted: 06/04/08 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
No problems so far.
2006 Cougar 294RLS TT - 2008 F350 Lariat 6.4L diesel 4x4 SRW SB. Reese WD w/HP Dual Cam, 2xHonda 2000i,Rotochoks,Levelairs,Toppoprails bike rack
JBarca
Dublin, Ohio, USA
Posted: 06/07/08 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
The Ford SD receivers are made well in my opinion. When I had a 1,200# tongue I could set the WD on the truck using the Ford receiver easy. No twisting/winding up issues. The weight just moved and responded to the hitch adjustments.
I did have to change mime out but only to get more tongue weight. The F250 and F350 SRW receiver have a 1,250# WD tongue limit. I needed more so I changed to a Class V Towbeast.
See this post which shows my change over with pics. F350 Receiver Upgrade - (Pic's)
Hope this helps.
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we where camping!)
