RV.Net Open Roads Forum: How can I clean mold stains from white rubber trim
 > How can I clean mold stains from white rubber trim
JTrate
Bernville, PA, USA
Posted: 06/04/08 06:03am Link  |  Quote  |  Print  |  Notify Moderator
OK, I spent the extra money for the Gel-gloss exterior on my '05. Several years down the road, exterior clean up is quick and easy with Awesome from the $1 store and an RV brush.
But.... The rubber roof extends over the side of the trailer and there is a rubber cover over the screw channel running the length of the whole exterior.
I tried everything and I can not remove the ugly black stains from the rubber.
I know some one out there in this vast on-line RV'ing community has some good tips for me.....
PS: Gearing up for my first two week trip over the 4th and I just can't wait to fill up the diesel tank (extra large) of my TV!!!
'03 Chevy Silverado LT 2500HD, Crew, 4x4, Duramax w/Allison
Prodigy Brake Controller
Cross Roads Paradise Pointe PF32BH
Annual trek to Disney's Fort Wilderness
OpenRoadsUSA
Lost In America!
Posted: 06/04/08 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Try softscrub,
On stubborn areas let it sit on the stain briefly.
I use it on the boat, and MH. Haven't found much better.
Also, on the boat, I have used toilet bowl cleaner on real bad stains, but be careful and wash throroughly and immediately if you use it. It has mild acid, which works good on the boat stains. Have not had any problem using it over the past 10 years. I would consider using it sparingly on the MH, if it was bad and the softscrub did not do the job I wanted. Think lots of water for rinsing on either product.
After using any product on the rubber roof, I would also use a rubber enhancing product when finished cleaning.
Good luck.
Current Location: Ingram, Texas
2006 Allegro 34WA
2007 Nissan Sentra
2006 Master Tow Dolly HD80
1999 Aquasport 21 Explorer
advntrs
greenwood, Indiana
Posted: 06/04/08 06:32am Link  |  Quote  |  Print  |  Notify Moderator
A good orange cleaner does a real good job on the vinyl screw trim.
beemerphile1
NE Ohio
Posted: 06/04/08 06:37am Link  |  Quote  |  Print  |  Notify Moderator
You say you tried everything but I doubt that. What did you use? I clean my roof, awning, and side walls with a solution of Awesome and Chlorine bleach.
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
AeroP
Emery, SD
Posted: 06/04/08 07:13am Link  |  Quote  |  Print  |  Notify Moderator
I have been there and found the solution. Remove the screws from each end and slide the molding out of the channel. Soak the molding in bleech water, dry and paint with white or matching paint.
Installing back in channel is not that difficult and the mold is gone forever.
AeroP
AeroP
99DSDP
1fastdad
mo.
Posted: 06/04/08 07:17am Link  |  Quote  |  Print  |  Notify Moderator
If its the plastic that covers the screws you can replace it. It comes in rolls with your choice of colors and width's. you can get it at most RV supply stores.
Carolina Cruiser
North Carolina
Posted: 06/04/08 07:30am Link  |  Quote  |  Print  |  Notify Moderator
I learned this from cleaning a shower, but for mold try white vinegar, Just spray it on, let it sit a few minutes, use a small brush and rinse. It works for me.
CSpenceFLY
Macon,Ga
Posted: 06/04/08 08:25am Link  |  Quote  |  Print  |  Notify Moderator
I used lacquer thinner on the trim around my door. It is the rubber type. It got a little sticky but it dried fine. If I had it to do over I would just replace it.
"You're lucky to be alive my friend."
Quote from the "Do it yourself police" and many others that have known me.
missourijan
Wherever our coach is
Posted: 06/05/08 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Sounds wierd, but the only way I can get my white vinyl clean is WD40. Use it carefully, like spraying it on a wet sponge, black comes right off, then clean it off with the awesome.
lv2rom
Kansas City, Missouri
Posted: 06/05/08 11:54am Link  |  Quote  |  Print  |  Notify Moderator
I'm sure many of these cleaning tips work just fine, but since you can buy new screw cover material for about $12 for 100' and with a lot less labor just replace what you've got....why not JUST DO IT!!!!....Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
