RV.Net Open Roads Forum: Tech Issues: Portable Rapid Charger
 > Portable Rapid Charger
ClassCRV
Valencia, CA
Posted: 06/04/08 07:31am Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at buying a 3 stage, high current, portable battery charger for charging a single deep cycle battery which I bring on trips to run my TV. I realize its not good for the battery to charge at a high rate, but I would still like the capability to maximize charging within a shorter generator run time.
Xantrex, Vector, Black and Decker, and Schumacher appear to be the choices.
The B and D is the cheapest at $55 from Amazon.
Anyone have any troubles with these models? Only real negative reviews I've read have been regarding the inability to charge a completely dead battery. I never let mine got down that far.
Thanks.
92 Jamboree Class C 24ft.
oujoker
Monterey, CA
Posted: 06/04/08 07:59am Link  |  Quote  |  Print  |  Notify Moderator
I believe most of the B & D units were made by vector last time I looked, those are very good units with battery reconditioning and user selectable charge rates. I have had very good results with vector/B&D chargers.
2007 Dutchman Express 31 Class C
2006 Centurion Elite V C4, Air Warrior
Beartoo
Perham MN
Posted: 06/04/08 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I have all kinds of BD products from bread makers, can openers, to power and hand tools and they have always be reliable.
DH - Bear
DW - Marge
Dogs, Rufus and Nelie
01 F 150
1999 Coachman TT
Norm K.
Destin, FL or on the road!
Posted: 06/04/08 08:54am Link  |  Quote  |  Print  |  Notify Moderator
I've got 2 B&D chargers. One is a compact 10a and the other goes up to 25. Less than $40 at a B&D Outlet. Very pleased with both.
'03 Silverado 2500HD Dmax/Allison XCab LB 4wd
'04 Montana 3400RL
smkettner
Posted: 06/04/08 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Get the 40 amp BD.
OnaQuest
Raleigh, NC
Posted: 06/04/08 08:59am Link  |  Quote  |  Print  |  Notify Moderator
It's refreshing to hear people NOT knocking Black&Decker for a change.
I have a BD/Vector 3-stage charger and it works great. I leave it in place of my converter most of the time. lou
Dyslexics of the world... UNTIE Visit www.Dyslexics.moc
MNtundraRet
Bloomington, MN
Posted: 06/04/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
I have the Schumacher Model 12000A. It is a heavy duty unit that can variable fast charge batteries (40 to 15 amp) with float mode monitoring to maintain batteries after charging.. Has 120 amp engine start and 2 amp slow charge. It will charge any type of battery (6 or 12v) and automatically adjust settings for each. It works as a battery & alternator tester, and will diagnose whether a battery needs desulfation, and will run the procedure automatically. The 2amp mode will bring up voltage on a very discharged battery, to allow normal charging. I use a 55 amp Optima Battery for my HD Television. The charger can recharge battery in less than 70 minutes max. Normal 50% recharge less than 30 minutes. Charger can easily take batteries to full 100% charge. The portable gives me an excellent backup if my 3-stage converter/charger ever failed.
Mark
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
Wherever I happen to park
Posted: 06/04/08 09:44am Link  |  Quote  |  Print  |  Notify Moderator
You could always put a PD 9280 in a plastic tool box with vented ends
jauguston
Bellingham, WA
Posted: 06/04/08 09:56am Link  |  Quote  |  Print  |  Notify Moderator
If I were doing what you want to do I would connect a pair of 4-6ga wires to your house batteries that you could clamp onto your TV battery. With your generator running your converter is powered so you could get some charge to your TV battery from it -- and also connect the portable charger. Using two charging devices on the same battery works fine and will charge quicker the either one by itself.
I have at times had up to four different charging devices charging one battery bank at the same time - no problem.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
ClassCRV
Valencia, CA
Posted: 06/04/08 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Jim
Wow, I thought having the house and another portable charger connected in parallel, and both charging, would cause problems.
Also, just recently I learned that its OK to use devices running off a battery while its charging. Seems a little scary to do so when charging at a very high rate.
