wayward1
rockbridge, ohio
Me: Under warranty for 13 more months (and or 50k miles). I just know there will be incidentals besides the $100.00 deductible
Rick and Kristi (KNR)
rcchallenger
La Mirada, California
Mine has been fine. My dad just had his turbo replaced due to sticking vanes and the truck has been runnning perfect ever since. I believe this is a common problem, especially if your truck sits too much or is only driven on short trips where the engine doesn't have an opportunity to reach optimal operating temperature. As long as you are under the 100k diesel engine warranty it will only cost the $100.00 deductible.
2005 Ford F350 XLT 4X4 SRW Powerstroke Diesel Firestone Air Bags
2006 Keystone Raptor 3612DS
2006 Yamaha WR450
2006 Yamaha YFZ450
2005 Yamaha TTR230
2006 Kinroad XT250CC Go-Kart
wayward1
rockbridge, ohio
This just in; Turbo too bad to clean, New turbo on the way from FMC, should be here tomorow!
Hawthorne
Oregon
Rust or Soot?
If soot, make sure they clean the egr system and intake as well.
Glad to hear it was as expected. Let us know the final outcome.
2004 Ford SRW 6.0 PSD, Gauges, Ranchos, Airbags w/ Cab Controler, 4400lb Rear Springs, Torklift Superhitch & TieDowns,
19.5” Visions w/ 265 Hankook DH01's
2003 Lance 1030, Air, Gen, Etc.
christivial
Alaska
A tech told me last year to take it off the vehicle and beat it with a mallot. That usually frees them up, then run it hard on occasion and slack off on the idle time. Kits(for PTO's) are availible to bump up the idle but they really down the fuel. Catch 22!..........CV
wayward1
rockbridge, ohio
Well here's the good and the bad;
Ford replaced the turbo under warranty, also cleaned the EGR.
The tech told me my EGR was not bad but he cleaned it anyway as it was apart. The turbo had rust and a small amount of soot. The replacement turbo was a remanufactured unit. All the work was done under warranty and I was only charged the $100 deductible.
Now for the bad;
The truck ran good for about 100 miles and started doing the same thing. When applying moderate throttle the coughing sound in the air cleaner followed by a buck then the trans would down shift and she'd take off.
Dropped her off at the dealer last night will call when open.
Any ideas, any one??????
stickyeye
New Jersey
Make sure they keep the first job ticket open so you don't get charged another deductible fee.....been there done that.
1150 AF Truck Camper, gen-set, pretty well loaded
Torklifts, superhitch w/48" extension, firestone air bags, energy suspension bump stops, fast guns
2005 Ram Quad Cab 3500 Dually. CTD, auto, 4.10's
sljkansas
Miami Co. Kansas
My turbo went out at about 81k, and took 3 remans. to get a good one. One never made it off the dealers lot. Now 160k and all ok.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter in College
Miami CO. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
wayward1
rockbridge, ohio
Spoke to the dealer yesterday morning about 15 minutes after they opened. Already had truck inside and was looking at it based on the note I left with the keys. Later in the day I was told the EGR valve was bad and a new one was being installed. The tech had cleaned the original EGR and said it was not very dirty. Anyway I should get her back today and will see.
BTW; could it have been the EGR all along?
wayward1
rockbridge, ohio
Had the truck back for a week or so now, the EGR replacement solved the problem. Dealer handled it on the 1st work order so I only paid one deductible. The truck seems to run better than ever with a slight increase in fuel economy. If ever in Logan Ohio and need a dealer I would recommend "Tansky Ford"
BTY I researched buying and extended warranty sold and backed up by Ford. The cost of the warranty is very close to what this repair would have cost out side of the warranty. There is a thread running on "TheDieselStop.com" titled Ford 200k plan with a lot of info. May be useful to any of you who are still in warranty as you can buy the extended warranty if you want.
