RV.Net Open Roads Forum: Truck Campers: Who all hauls a box trailer?
 > Who all hauls a box trailer?
Boatycall
Tacoma, WA
Posted: 06/04/08 09:58am Link  |  Quote  |  Print  |  Notify Moderator
I just picked up an enclosed trailer for the jeep, and just stuff in general. Taking the whole thing out this weekend. It's a 24' 10,000 gvw. I'll never come close to that with just the jeep inside, or at least I hope so. Plan on hitting the scales on the way out to where I'm going.
Just wondering who else hauls one, and any changes you've made. I'm looking for a large awning for the side of it.
'01 F350 CC DRW 4x4,4" turbo back exhaust,SCMT,pyro tranny temp& boost gauges,4.10 gears
'03 Arctic Fox 1140,4 Trojan T105s,1.5kw inverter,icemaker
92 YJ 35's,6" lift,ARB lockers,Ford 8.8, 8k winch
Honda 400ex
10k 24' toybox
221, 221, whatever it takes.
wayward1
rockbridge, ohio
Posted: 06/04/08 10:04am Link  |  Quote  |  Print  |  Notify Moderator
We pull a 14' enclosed. Just use a 21" hitch extension and w/d hitch. No problems. BTY it a 7K and we get close to that at times. Good luck with the new "tote".
Rick and Kristi (KNR)
F350OilBurner
Central MA
Posted: 06/04/08 11:37am Link  |  Quote  |  Print  |  Notify Moderator
I pull that exact size and gvw trailer made by Classic Manufacturing. I haul my Corvette to shows. I have not weighed the pair but I estimate I'm at about 22K lbs. That would be 14K for the truck/camper and 8K for the trailer with car and tools. That is based on the truck/camper having been weighed and knowing the trailer and car weights. At some point I will weight the combo to get the tongue weight.
The truck has Airlift Superduty Airbags, Timbrens and extended overload bumpstops. I use the Torklift Superhitch with a 42" extension and a Reese weight distributing hitch setup. I hardly know the trailer is back there other than having to pull harder going up hill. No sway, no jerking, no bounce... I have to keep checking to make sure it's still there. The mileage also drops about 1 mpg.
* This post was edited 06/04/08 11:54am by F350OilBurner *
2006 Ford F350 Lariat CC LB DRW
6.0 PSD w/TorqShift 4x4 4.10LSD
Airlift Airbags/SureSet Controller - Timbrens
2007 Lance 1181 - All the Options
Torklift Superhitch/Tiedowns/Fastguns
nny12972
NY
Posted: 06/04/08 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Don't know about towing with a TC, but I installed two 12' awnings on mine----one on each side so I could keep the Sportsters dry, too.......$1,350 for two with tax, and I saved the dealer's $850 installation charges! A two-man install for sure, but definitely a D-I-Y if you're at all handy.
J
Mosandman
SE Missouri
Posted: 06/04/08 11:55am Link  |  Quote  |  Print  |  Notify Moderator
I changed out the trailer brakes from electric drum to electric over hydraulic disc brakes. I haul cars and cycles for myself as well as others.
I also added in a 2nd breakaway switch and battery for redundancy.
* This post was edited 06/04/08 12:09pm by Mosandman *
Moomba2002
Sebastopol, CA
Posted: 06/04/08 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have an 8.5X16 enclosed trailer for quads etc. I use a 41" extesion and W.D Bars and it tows like a dream. For whatever reason, and I have been working a lot on it the truck and camper haul better with the trailer or boat attached than just the truck and camper.
1999 Ford F350 DRW 4X4 PSD 6spd.
Banks Stinger Package
Fords upgraded Air Intake System
ExtremeAire 150 PSI 100% Duty Cyle on board air w/4gal. tank
Air Bags & Rancho 9000's
2003 Arctic Fox 1150 loaded except solor
Cuttership
IN, USA
Posted: 06/04/08 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
click on the photo I haul two 600 pound each ATVs and gear
2000 Chevy Silverado 2500 4X4 , long bed, Excab, camper Apache[img]]
Note: Due to invalid formatting, all formatting has been ignored.
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/04/08 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Take a look at your rear springs with just the camper versus with the camper and trailer. On mine, with the stock springs, with just the camper, the main springs didn't sag quite enough to get the frame to sit down tight on the overloads, so it rocked a bit more than I liked. With the trailer hooked up, the tongue put just enough additional weight on the main springs to sag them so the frame rested down onto the overload springs and then it rode more solid and flat in the curves. Ford builds these trucks with not quite enough arc in the overload leafs to make them contact the frame bumpers unless very heavily loaded.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
Crumm
Fairbanks Alaska
Posted: 06/05/08 02:47am Link  |  Quote  |  Print  |  Notify Moderator
"Who all hauls a box trailer?" I do..
96' F350 PSD with smoke added, Airbags, Trailmaster SSV shocks, 315/75R16 Toyo M/T, Centering guides.
06' Adventurer 90FWS with leg extensions
06' Jetcraft XS.
94' Wells Cargo 7'x14'
Slide-Show
~DJ~
Boise, Idaho
Posted: 06/05/08 08:00am Link  |  Quote  |  Print  |  Notify Moderator
I haul a 7x16 for my quad and trail bike. I built storage compartments for extra water, gas, riding gear and camping gear like the screen tent which I normally would not take without the trailer. Works very well.
Since this picture I have added my float tube on the left wall and barriers to hold the stuff on the shelves. I also finished and insulated the ceiling.
05 Dodge Ram 3500 SLT SC DRW 4X4 CTD G56 373's CAI,Edge Juice/Attitude,Jake,Rancho9000x,Torklift tie downs,Superhitch,Stable Loads
04 S&S Avalanche 9' with slide
26th Marines RVN 69-70 Semper Fi
M-14 was the only Woodstock I saw in 1969.
