RV.Net Open Roads Forum: Home made P 30 Rear Trac Bar Pic's
 > Home made P 30 Rear Trac Bar Pic's
billyboy
md
Posted: 06/05/08 04:48am Link  |  Quote  |  Print  |  Notify Moderator
bill, how long was your bar. it looks as if it goes from side to side.
Remember: "Its Not The deal You Got, Its The Deal You Think You Got"
'08 Windsport 33 followed by 2000 Saturn
Learjet
Louisiana
Posted: 06/05/08 07:15am Link  |  Quote  |  Print  |  Notify Moderator
wouldn't that be more of a sway bar, than traction bar?
2006 Nissan Titan CC with tow package
2006 KZ Frontier 2303P-F
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
purplekeenah
greensburg, pa
Posted: 06/05/08 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Learjet, the TRAC bar does not refer to traction, the term has to do with how the rig tracks down the road in a straight line versus side to side movement caused by passing trucks, crosswinds, etc.
Jer
2003 Condor 1340 P32 Chassis
Workhorse 8.1
2006 Chevy HHR
RJsfishin
Winston Or.
Posted: 06/05/08 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Jer
That throwed me for a curve too. There are sway bars, and there are traction bars,....and this is a sway bar.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
Gale Hawkins
Murray, KY
Posted: 06/05/08 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Now I am confused. My 1992 P30 chassis has a very heavy (1 or 1.25 inch) sway bar that came with the MH due to the looks of the set up and the age. Do all P30's come with this?
Mine left the factory with a 190" wheel base but I guess due to sitting in a MI field in the rain she grew to 208" before the house went onto her back.
I have never had a sway issue that I have detected after driving it for 3000 miles now.
mich800
Pontiac, MI
Posted: 06/05/08 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Actually no, this is a third type of device. An anti sway bar connects both sides together. A trac-bars only function is to locate the rear end and center it throughout its travel. It is more common on coil sprung type suspensions.
ScottG
Bothell Wa.
Posted: 06/05/08 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Another way to look at it is that it keeps the rear end from moving sideways under the rig (leaf springs alone aren't very good at this). That's why I thought it may be a good addition for a heavy trailer as well.
Thanks for the info guys.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
BluegrassBill
Woodland, Wa. USA
Posted: 06/05/08 11:01am Link  |  Quote  |  Print  |  Notify Moderator
billyboy,
Total length of the top link installed is 30" Both ends screw in and out so it can be shortened or lengthened as needed. This coach almost drives like a car, Tracks true and straight. Passing semi's and crosswinds are hardly noticed.
Bill & Kathy Francis
95 Itasca Sunrise 29RQ,P32 454 Chevy, Banks,ECM chip.Safe-T-Plus, Bilsteins, Super Steer Bell Crank, Stewart Stage 1 Waterpump, Severe Duty Fan Clutch, OilGuard Bypass Filter, Coolant Filter. Rear Tracbar. 1-5/8" Front Swaybar.
sum1
So-Cal
Posted: 06/05/08 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
Sway bars resist roll and track bars resist yaw. The simplest track bars like the one Bluegrassbill built are Panhard Arms.
RJsfishin
Winston Or.
Posted: 06/06/08 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Agreed, it is not a sway bar. I never knew the name of that bar, but I know what it does, and they are common on many vehicles.
IMO, 30" bar is too short (on such a wide vehicle) to keep the body centered over the rear axle housing thru out it distance of travel. It would be forced to continually move from side to side. The longer the bar, the less side movement there would be.
