Hi all, just joined the forum. We are in the process of buying our first Class A. Plan on going full-time in a year. We are seriously looking at these 2 mh's:
1. new 06 Georgie Boy Landau 3650ts. dealer is offering a 5 year warranty due to its age
2. new 07 Four Winds Windsport 36e
Your advise, thoughts, suggestions and comments would be great. I've also heard a little about PDI's, how/ where do I get these?
Thanks in advance
they are both about the same ,imo. the landaus are no longer being made and the windsport is. we originally started looking at the landau while having a pursuit, but gbm stopped the production. i like the windsport a little more then the gbm. they have a rich looking interior.
Remember: "Its Not The deal You Got, Its The Deal You Think You Got"
'08 Windsport 33 followed by 2000 Saturn
PDI - is Pre Delivery Inspection.
That is when You and the dealer Rep walk through the rig to make sure everything works. They explain how it ALL Works, and actually demonstrate that it does indeed work.
(It probably won't all work or you will find something that needs to be taken care of)
The Dealer should also do their own PDI in an attempt to have the rig ready to go when you do your walk through.
we have a 05 windsport 34ft, no major problems with it, just make sure you go thru the inspection with a fine tooth comb, i mean every inch by inch from top to bottom, we had alot of little things when we first got it that should have been found before it left the factory
