camping man
Central Fla.
Mine changed when I lost my cat.,maybe a piece of your broke off inside. Sometimes they over heat and crumble inside. If your cat is gone, it'll smell like the old city bus exhaust, or an old tractor.
05 Dodge 2500 Quadcab CTD NV5600/3.73rears
97 27ft.Sprinter 5er
Website
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Maybe it is just like when we went from leaded to unleaded and added a cat to the exhaust, the smell changed. If your truck runs the same don’t sweat it. As for changing out the injectors I have never seen a whole set go out at one time. It sounds to me like the dealer is finding a different way to bring his profits up.
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
pics
Kenneth
Washington, the state
Glen
Try a different brand of fuel. There are differences between fuels, and if you buy regularly from one station, they might have switched suppliers. Several of the stations in one area may have the same supplier, so switch more than once if needed. The people at the station might know the supplier, or maybe just the name of the trucking company that delivers the fuel to them.
erd04056
Where ever we park it
Have the injector balance rates checked. They should be within +or-4 in park and +or-6 in drive or reverse whit the engine fully warmed up. Although injector problems are considered rare on the LLY motors...it was a very common issue on the LB7 motors.
2005 Kodiak 4X4
40' Carriage 5th wheel
GMC_Man
Arkansas
erd04056 wrote: Have the injector balance rates checked. They should be within +or-4 in park and +or-6 in drive or reverse whit the engine fully warmed up. Although injector problems are considered rare on the LLY motors...it was a very common issue on the LB7 motors.
Being an '06, he should have the LBZ motor. I don't think its would be injectors in this late a year model. That was maining the 01 and 02 and some 03s. When I had my DMAX, ULSD did smell different than LSD.
2007 GMC Sierra 1500 Crew Cab Z71 with VortecMAX 6.0 V8
2005 Forest River Flagstaff 831BHSS
PAUL3500HD
N.W.Ohio
Mine is an 06 and has the LLY in it
Early 06's hadn't changed over yet
Not sure what he is smelling
2006 3500 Silverado CC D/A Dually 4x4 LT3
Summit White
15K REESE
2005 K-Z Sportsmen 3052px2 Limited
Prodigy
MY PICTURES
More Pic's
3500 DUALLY CLUB MEMBER # 128
geewiz
Canada & Mexico
Yes it is a late '06 LBZ.
These are all good suggestions. As it is my first diesel, I am trying to learn what makes it tick.
I will report back after service, which is due soon.
Thanks,
Glen
geewiz
Canada & Mexico
Smell is gone...
I mentioned that service was due -- actually the"fuel filter life" had worked its way down to 0% and the "replace fuel filter" message came on each time I started up. This happened a couple weeks ago about the time the exhaust stared to smell. Co-incidence? I guess not. The Chev garage said my fuel filter was very dirty.
So I guess that was it. i will be more diligent next time.
Glen & Susan
and our mascot, Pippin
ACZL
UPstate,NY
chadsalt wrote: I think some of you guys are spending to much time 'sniffing' the exhaust.
"Diesel fumes make you horny!!"
2003 F250 SD,CC,4x4,SB,AT,Lariat,6.0PSD
2006 Cedar Creek Silverback 33 LBHTS "Custom"
Member of The Cedar Creek RV Club
"Creekin' in the Summer"
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Dale_S
Saugus, CA
I have an LBZ and noticed the smell changes depending on where I buy the fuel at. When i buy at the C* it smells like it always did, but if I buy it at the off brand place which is a few cents a gallon cheaper, it has a rank (Rotting) smell mixed in with the normal diesel smell.
2007 Chevrolet Silverado Classic 2500HD Duramax 6.6
2008 Jayco Eagle 299RLS
