FreeLanceing
Grand Haven Mi
I have been looking for a way to plug the camper in without splicing into the truck harness. Up here in the salt country seems like no matter what you do the salt will get to it. I have looked at the torklift set up with a separate charge line. I seem to recall a post where someone found a harness that plugged into the back of the exsisting 7 way on my GMC. This would actually enable you to use the factory 7 way and run the new harness forward to the bed of the truck. I understand the need for a separate charge line. I did a search but could not find it. Thank you.
JumboJet
Tontitown Arkansas
Wiring Harness
Here is where I purchased mine.
VintageRacer
Dundas, Ontario
My camper has a 7 way plug near the front under one wing. The plug is the standard trailer type, and I just have a long cable that runs back and plugs into the factory trailer plug on the rear bumper of my truck. I added a "y" splice that adds in the trailer wiring for my trailer. The truck charges the TC through the standard charge wire in the 7 pin connector and cable, no separate wire. It works just fine.
Brian
2003 Dodge Ram 2500 Quad Cab, Hemi, 5 speed manual, 3.73 gears, Tow Beast hitch with 24" extension.
28 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
2004 Travel Hawk 8' Truck Camper - Roll at 16K combined weight
enblethen
Moses Lake, WA USA
Tork-lift makes several different cables similar to what Jumbojet posted.
Bud
Suzuki XL7 pushing Pace Arrow
FreeLanceing
Grand Haven Mi
I was hopeing to find one that plugs into the back of the factory plug thus leaving the factory plug for the trailer. I know I have seen these somewhere. The torklift style will work fine just you always have that thing plugged in and the pig tail hangin out there. Then when you don,t have the camper on like all winter its still there.
jsmmv
California
You might try eTrailer.com
Jeff
Hey there
Pendergrass, GA
Hey FreeLancing, Hi,
If your truck has the trailer towing pkg, it may have another wiring harness up under the front of the bed on the driver's side. Mine supposedly has one. It's described in the owner's manual and in the factory manuals. But, I have been unable to find mine.
Kurt
2001 Silverado 3500 DRW CC LB 6.0
1993 Lance Squire Lite 150 (8'6")
2001 Fleetwood Caribou 11J (11'6")
FreeLanceing
Grand Haven Mi
My truck has the trailer towing pkg. I have not been able to find that myself I think you had to specify a TC harness it is 50 or 45 option for the new models today anyhow. Someone out there knows how to do what I want to do because I saw it on here.
enblethen
Moses Lake, WA USA
Tork-lift model W6524,W6532, and W6548. Each plugs into the existing seven way, has extension for camper and a trailer connector, all seven pin.
KMLsquared
Rohnert Park, CA
Here is how i did it on my Dodge.
Nice and clean.
reese 118384 appears to be the one you need. A test light will help you determine the remaining splices
2002 HO 6spd LB QC 4x4. Edge Juice w/Att 4" str8 pipe AFE int Skyjacker D25 springs w/10" Fox Shox 2.0 Thuren track bar PSC Steering box w/DSS. Fox Steering Damper w/custom mount.
1993 Fleetwood Caribou 10HX
2001 Warrior
2002 Banshee
1969 Baja
