RV.Net Open Roads Forum: Tech Issues: Fridge temp sensor qeustion
 > Fridge temp sensor qeustion
flakjacket
Fremont, CA
Posted: 06/05/08 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Can some tell me which way to move the little slide switch on the fins in the fridge to lower the temp?
Thanks'
Ed
rvsatek
AZ, USA
Posted: 06/05/08 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Move the thermister up on the fins to lower the temp.
Larry
1994 Ford F250/7.5L/410 gears
2001 Keystone Sprinter 276RLS 14' slide
flakjacket
Fremont, CA
Posted: 06/05/08 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Great, Thanks
Jerrybo66
AZ
Posted: 06/05/08 09:30am Link  |  Quote  |  Print  |  Notify Moderator
I remember it as being opposite. Down on the thermister, up on the temperature. Up is down on the temp.
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
javaseuf
Southern Cal
Posted: 06/05/08 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Nope. It's the other way. That thermistor is raised to sense the warmer air that rises so the cooling system operates longer.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
CamperAndy
Coeur d'Alene, ID
Posted: 06/05/08 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
The thermistor is sensing the fin temperature not the air temp. If you want it really cold in the fridge pull it off the fin completely and let it hang in the air.
2005 Keystone Outback 28rs-s
www.Outbackers.com
2006 Ram 3500 Mega Quad, 5.9 Cummins, 3.73 gear (not yet pictured)
Prodigy Brake Control
2005 Kipor KGE3500Ti Generator
javaseuf
Southern Cal
Posted: 06/05/08 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Hummm, my sensor is enclosed in a plastic sleeve and not touching the fins. If it touches the fins, which is below freezing at times, it would short cycle the refer.
1fastdad
mo.
Posted: 06/05/08 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
You just said the same thing rvsatek said.(up to lower temp & down to raise temp) I agree.
