BIGDOMINO
Full Timing since July 13th 2007
This may be a strange question, but here goes. I am wondering if there is a difference in cooling an engine when the humidity is high? If you were traveling down the rode and it is 90 degrees, would the humidity level make any difference in how well the engine cools?
Thanks.
Steve__
Steve & Toni__
38 foot Monaco knight with every option available.
2001 Honda CRV in tow.
Wife running the show.
95 pound Golden named Max loving the ride.
FULL TIMING AS OF JULY 13, 2007
Kenneth
Washington, the state
No.
Gale Hawkins
Murray, KY
Not in any real sense would be my take. Cold and heat indexs only apply to living matter is what I have been told.
henchman
Cardinal, Ontario
In theory, more humid air should cool better as it's density is higher, that's why we use fluids to cool the engine instead of just air. However, I doubt it makes any real difference in engine temps.
Ian
1991 Winnebago Warrior 30eu
OLD RIG
2006 Chevy Uplander 3.5l
2005 Jayco Sport 165 18' 3500lbs loaded
Putnam WD w/800lb bars
Acar friction type sway control
Hoppy digital display brake control
BALANCED tires! (Please everyone, balance your tires!)
KOG
Winterville GA
No difference in practical terms. Evaporative cooling from sweat does vary greatly with humidity. Your radiator doesn't sweat (unless it leaks).
jauguston
Bellingham, WA
No
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
marvmarcy
Polson, MT, USA
Well, the answer is a qualified yes. The higher the humidity (more water) the more heat can be absorbed and held. However, since the air and the little bit of water in the air is already at 90*, it won't be of any consequence. It is fairly common knowledge that you can help cool an overheated engine by running a hose over/through the radiator while the engine is running, but much of the extra cooling happens because the water is much cooler than the ambient air temperature. Even so, water is denser than gas, so it will absorb and hold more heat or cold. In practicality, the answer is no.
JMHO
Marv
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
sum1
So-Cal
As I remember from flying small planes and helicopters, water vapor is less dense than air. Engine power was considered to be slightly less in humid conditions. Now liquid water is another matter!
Wherever I happen to park
Actually.. Humidity does make a difference. HOWEVER what difference it makes depends
Straight engine. the higher humidity air can hold more heat and thus cool the engine better than dry air
however you are more likely to run the A/C to cool the driver (A good thing actually) and this "pre-heats" engine cooling air (That heat needs to go somewhere) so this results in the engine running with a bit less, overall, cooling (Plus a higher work load)
But generally the more humidity in the air the better it is at absorbing heat from an engine
Since you are cooled by the evaporation of water.. It works the other way around for you.
