RV.Net Open Roads Forum: Towing: Tight lug nuts on TV
Search only in Towing
Open Roads Forum  >  Towing
 > Tight lug nuts on TV
geneo2004
Pleasant Grove Utah
Posted: 06/05/08 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
I recently wanted to check the brakes on my Dodge 2500 CTD and found the lug nuts so tight that I didn't have a tool that could loosen them. I shattered a socket trying. What do others do. Also, when I took it to a tire shop to do the check, they used a torque wrench to tighten them to 120 lbs. Is this normal? Any suggestions what to do if I ever have a flat?
reno82
Cardiff by the Sea, CA
Posted: 06/05/08 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
I always carry a 4-way lug wrench because of the extra torgue you have, and so I'm always covered for any size lug...My TV and TT are different sizes. Never met a lug I couldn't loosen with a 4-way.
Charlie D.
Gonzales, La.
Posted: 06/05/08 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
My 2006 D/A 3/4 ton calls for 120 ft/#'s torque. Check your owners manual, it may have torque values.
Enjoying Your Freedom?
Thank A Veteran
2007 Holiday Rambler 32SKT
2006 Chev LT D/A CC
bigeking
Arlington, Texas
Posted: 06/05/08 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
Buy a socket that is for an impact wrench, and you can either buy a breaker bar, or get a piece of pipe two to three feet long that will fit over one end of your 4-way. The pipe will give you more leverage, and you can also push with your foot on the other side of the 4-way.
Everett
2008 GMC Duramax-Allison Extended Cab Dually Locking 3:73 rear end
Line-x bedliner Pullrite hitch hidden very nicely under Retrax Bed Cover---2008 Nu Wa DA 339RSB
mainetom
Maine, near Augusta
Posted: 06/06/08 04:22am Link  |  Quote  |  Print  |  Notify Moderator
When you get home after having tires rotated or other service, it's a good idea to check lugs for over/under tightness. Same for inflation pressure. Lately they just can't seem to get it right and I'm really glad I checked.
John3872
Iowa
Posted: 06/06/08 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Air impact with impact an socket. I torque lugnuts to 120 ft. lbs.
2001 GMC 2500 6.0L
2006 Rockwood 8281SS
Reese 16K Fifth Wheel Slider
DrawTite Brake Controller
Kenneth
Washington, the state
Posted: 06/06/08 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Gene,
The last shop that tightened those lug nuts didn't do it right.
An ordinary socket and breaker bar with you standing (or bouncing) on the handle will loosen nuts tightened to 120 lbs-ft. Yours were way too tight. I'd suggest that in the future you insist on witnessing the torquing of your lug nuts. Tell them that you require to see each nut turn slightly before the torque wrench reaches the specified torque, 120 in this case. Accept no excuses or, "we always do it THIS way." The customer is always right, and you are the customer. Quietly, calmly, say, "No, do it my way."
donn0128
Pronounced Ore-gun
Posted: 06/06/08 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Buy a torque wrench and proper socket. Carry two sockets, one for the trailer and one for the truck. Always check them yourself for proper torque. And yes I believe that Dodge lists 120lb ft as the proper torque. At least for my dually it is.
Donn
BenK
SF BayArea
Posted: 06/06/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
If steel wheels, could be, most likely be rusted mating surfaces between
the lug nut and wheel's coined hole.
If alloy wheels, could be, most likely galvanic action between the
aluminum and steel lug nuts at the mating surface.
And/Or the lug nut threads and studs have rusted, or has dirt/sand/grit/etc
that has gouged the mating surfaces.
Over tightening 'usually' has the stud streeeeeeetch and lesser torque
or holding/clamping forces because the metal has gone past it's yeild
point.
Lug nuts/studs should be torqued in a criss cross pattern and in ever
increasing steps till the final torque with the full weight of the
vehicle on the tires.
My 1996 Suburban 8.6Klb GVWR truck spec's out 140ft/lbs
-Ben Picture of my rig
Cat320
Western AR
Posted: 06/06/08 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Go to Harbor Freight...24" breaker bar with 1/2" drive...$10 guaranteed for life.
They also sell a 1/2" drive torque wrench for $20, or if it's on sale, $15...also guaranteed for life.
