RV.Net Open Roads Forum: Truck Campers: TC & Boat Trailer Plug
 > TC & Boat Trailer Plug
dieselgrin
Virginia
Posted: 06/06/08 04:05am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone seen an adapter that you can use to plug both the TC and the flat trailer type plug into your truck? Standard big plug on TC and truck. Need a way to run the lights on the trailer while hauling the TC.
2002 Silverado LT, 2500HD, Duramax, Big Allison, 4x4 Crew
Bridgestone Dueler A/T Revo 245/75/16,...
Fleetwood Angler
Mark Heisler
Viking,Alberta Canada
Posted: 06/06/08 06:43am Link  |  Quote  |  Print  |  Notify Moderator
i think what you are looking for can be bought at cablas.
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
Wolfe
Palm Beach Gardens, Fl.
Posted: 06/06/08 07:24am Link  |  Quote  |  Print  |  Notify Moderator
I made my own, real easy and probably a lot cheaper, I soldered the connections.
Photomike
Southern Alberta
Posted: 06/06/08 07:38am Link  |  Quote  |  Print  |  Notify Moderator
I have one sitting on the desk in front of me. Nice one piece unit, cost was $16.00.
Mike
2002 GMC 2500HD 4x4 4 Door
1992 Northern Lite 9'- 6" Camper
Gamagoat
NorCal
Posted: 06/06/08 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I replaced my oem Pollak 7 pin receptacle with the picture below. Since I lost two of my 7 to 4 pin flat connector adapter it is worth the upgrade. Made by Hopkins btw and they are available at Autozone for $25.00
* This post was edited 06/06/08 11:37am by Gamagoat *
06 Silverado HD2500 DA/CC/SB/LT3
Line X/Timbren/Rancho 9000x/Bodiak Front Hitch/Reese Tow Beast Class V with 24" Stinger
06 Lance 845/Honda EU2000
jlfiber
Omaha
Posted: 06/06/08 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Ford's better idea for 2008 (it was similar to the pic above in 2003)was to place the doors left-open / right open so when you have the 4 Pin in you cannot open the the 7 Pin door far enough to get the connector in. You have to cut off part the "tabs" on both the 7 Pin connector and the door and force the 4 pin door hard to the right to get the connector in. I'll never figure out why they let these engineers design a truck with a "Camper Package" when they don't even own (or probably even never seen) a camper. They should be designed by the guys on the line and assembled by the guys with the ties on!
2008 F-350 CC SRW LB 4x4 V-10, 2008 Northstar Igloo 9.5
Photomike
Southern Alberta
Posted: 06/06/08 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Just thought - when I bought my truck the sales person was saying that some trucks have the flat type next to the 7 pin. You may want to check this out first as the one that he showed me was a Chevy.
Mike
Haifisch
Silverdale WA
Posted: 06/06/08 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a Hopkins 40955 adapter for my '02 Silverado, it replaces the factory 7 pin and plugs into the factory harness. You get the 7 pin and a 4 pin flat right next to, works great for the boat when the camper is on it.
wnjj
Cornelius, Oregon
Posted: 06/06/08 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
If I had to guess, they probably didn't want the user to use both at once. Maybe the wiring/fuses aren't large enough to feed 2 "trailer's" worth.
jlfiber
Omaha
Posted: 06/06/08 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
The trailer wiring ckts for 1)running lights 2)brake lights 3)backup lights & 5)/6) left & right turn signals are each fed by individual 30 amp fuses. Not to mention the electric brakes and +12v. I think you are giving those automotive engineers wayyyyyyyyyyyyy to much credit.
