RV.Net Open Roads Forum: Tech Issues: 30 amp service vs 50 amp service
 > 30 amp service vs 50 amp service
lawrence617
High Point, NC
Posted: 06/06/08 05:55am Link  |  Quote  |  Print  |  Notify Moderator
I am still new at this and still learning about RVing. Question about running 30amp service, right now I have the RV parked and hooked up to 50amp. I am getting ready to move to another place where they have only 30amp service. What problems can I run into? Can I run the AC? I have 2 ac units, would I be able to run one of the AC units? Any suggestions or advice would be wonderful!
2006 GMC 4x4 2500HD Duramax/Allison Crewcab Shortbed
Roadmaster Active Suspension
Voyager Braking Kit
15K Reese Slider Hitch
2008 Jayco Eagle 345BHS
M GO BLUE
Southgate, MI
Posted: 06/06/08 06:01am Link  |  Quote  |  Print  |  Notify Moderator
50A Rv plugged into 3A service means you can only run one A/C at a time...you also have to watch what you run at one time...it may be possible to run A/C and micro at the same time, then again may not be able to...
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fith wheel
Built-In Onan 5500W generator
Polishnurse
Schodack, NY
Posted: 06/06/08 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Only One AC. You will also need a 50 to 30 Amp Adaptor (Wallmart sells them).
KID2TEXAS
Memphis, Tenn
Posted: 06/06/08 07:03am Link  |  Quote  |  Print  |  Notify Moderator
Everyone above covered it very well, good luck...
2006 Ford F-250 Super Duty, Amarillo Special Edition 4 X 4 & 6.0 PSD,
Tow Haul/Tow Boss/Tow Command, 18" load E tires standard.
Me, a Wife and two crazy kids
2006 Holiday Rambler, Next Level 38FKS
Ray,IN
IN, USA
Posted: 06/06/08 07:11am Link  |  Quote  |  Print  |  Notify Moderator
This wattage chart is very helpful to some folks.
I suggest buying a line voltage monitor. As long as you keep the indicator in the green zone your appliances are safe from damage.
USA in a Chevrolet
Manahawkin, New Jersey
Posted: 06/06/08 09:13am Link  |  Quote  |  Print  |  Notify Moderator
We have a 50 amp service & two AC's. Many times, only 30 amps is available. We can run one AC & everything else using the 50 to 30 amp adapter. This includes Microwave & small electric heater. I'll bet if anything trips it is due to low park voltage not your fiver.
goin2themountains
Aztec, NM
Posted: 06/06/08 09:27am Link  |  Quote  |  Print  |  Notify Moderator
As I only have 30amp to my 5er, but can run AC, micro and television at same time, I don't know why you couldn't run 1 AC with the adapter.
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
bassmanbrad
houston
Posted: 06/06/08 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
+1. The only time we ever had a problem is when we were cooking and spilled something- turned the vacuum on while the microwave was running and tripped a breaker.
smkettner
Posted: 06/06/08 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
The breaker will tell you when you pull too many amps. Otherwise keep an eye on voltage stays above 110 when running one a/c and especially if running both. Once you get moved let us know how it does.
sirdrakejr
Las Vegas, Nevada
Posted: 06/06/08 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from 5th wheels to tech issues.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
