RV.Net Open Roads Forum: 4 pin twist lock to the 30amp RV plug?
 > 4 pin twist lock to the 30amp RV plug?
lotust
Long Island NY
Posted: 06/06/08 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guys, I have about 200' of the yellow marine grade 10ga cord that Im looking to utilize. does anyone know where I can purchase and convert this 4 pin male setup to the camper 3 prong female?
Sorry if this has been asked before. I did not find an answer in my search.
  • 2006 Jayco Jay Flight 27 BH.(paid off :-)
    2008 toyota tundra 5.7L w/tow Off road Pkg. (not paid off)
    Honda Eu2000i
    The wife and the dog Loving Camping!
Shotgun
CA
Posted: 06/06/08 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
first, do not run 200; of #10 for 30 amps, will not hold the load.
but the plug can be picked yo at home depot
Hunting is not a hobby. It is much more life sustaining than that.
Dale-pilot, Jeanette-co-pilot
Electrician since 1978
2003 30' Sprinter 5er
2001 Dodge CTD
lotust
Long Island NY
Posted: 06/06/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Sure I know that :-) I just have it at my disposal. I think Im confused on how to wire 220v to the camper that has only 3 wires. Is there a write up some where?
Shotgun
CA
Posted: 06/06/08 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
just cut the red wire short, and tape it safe, on both ends.
DO NOT wire 220v to your camper.
the black is hot, 120 v
the white neutral
the green is ground
john b
anywhere USA!
Posted: 06/06/08 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
DO NOT RUN 220 to you rig or you will fry everything!!!!!!!!!
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2004 Crossroads Paradise Point PF33Rl 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
Kenneth
Washington, the state
Posted: 06/06/08 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
What?
30 amp RV service is 120 volts, and the 30 amp RV cord has a 3-prong male plug. The receptacle and plug are NEMA TT-30. One leg is 120 volt hot, one leg is neutral, and one leg is ground.
lotust
Long Island NY
Posted: 06/06/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Ahhh Ok thanks for that info guys. Is there and danger of hitting the 120v/220v switch on my generator when I have the twist lock plug in ? Im not sure what the point of the twist lock 30amp outlet is for?
Thanks for clearing up the 220v thing. I was wondering if the camper inverter switched something inside to down power the 220v to 120v
thanks again,
nny12972
NY
Posted: 06/06/08 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
.......and 30A RV plugs are three-prong 120V only...
J
BurbMan
Long Island, NY
Posted: 06/06/08 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Marinco makes the connectors you are looking for. They have an RV conversion kit that allows you to remove the hardwired RV power cord and install a male 30A 125V twist-lock fitting on the side of the RV. I have it on mine.
Click the photo:
lotust
Long Island NY
Posted: 06/06/08 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
the white neutral
the green is ground
Ok if I wire it like this is there any danger of me bumping the 120v/220v switch while the generator is running and frying the camper? or is this impossable with out having the red wire connected?
I have the pepboys 3500 watt power pro.
