RV.Net Open Roads Forum: Class A Motorhomes: Finding HWH oil
 > Finding HWH oil
billbrit
Nevada
Posted: 06/06/08 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
I want to top up my hydraulic oil for my jacks, but I can't find anyone who sells HWH oil. My manual says to use only HWH. I called the co. and they said it's OK to use Dexron III, but now I discover that Dexron III is no longer being made. Do I have to buy from HWH and pay shipping etc?
Deen
Vancouver, WA
Posted: 06/06/08 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
The only difference between the Dexron and HWH fluids is that HWH doesn't have any color added to it. Just use the Dexron, that's what HWH says for our system.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
Herculez
North Carolina
Posted: 06/06/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Camping World I think carry's it.
You may also want to call RV dealers that have RV's that have the HWH system. That is what we have.
You can still get DEX lll, It just does not say dex lll. It will read multi purpose transmission fluid.
Hope that helps,
Britt
CSpenceFLY
Macon,Ga
Posted: 06/06/08 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
If you need confirmation why not call back HWH?? It's hydaulic oil. As long as you make sure it won't eat the seals you will be fine.
"You're lucky to be alive my friend."
Quote from the "Do it yourself police" and many others that have known me.
96Bounder30E
Birthplace of the Boysenberry, Orange County, CA
Posted: 06/06/08 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Transmission fluid is what HWH recomends.......the difference between tranny fluid and real deal HWh fluid is the red dye.......
If I recall.......the manual says to use tramsmission fluid in the event HWH oil is not available...........
* This post was edited 06/06/08 06:58pm by 96Bounder30E *
tom_kat
way upstate new york/lake george area
Posted: 06/06/08 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
my older model uses dextron tranny fluid
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
st687
tampa Fl
Posted: 06/06/08 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Pennzoil Multi V is a replacement for DexronIII.
Doris &Bill
97 U270 Foretravel
05 Saturn Vue 265HP
When all else fails call a MARINE
Semper Fi.
Kenneth
Washington, the state
Posted: 06/06/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of oil companies still product Dexron-III ATF, but they can no longer use that name. Look for ATF named D-M or M-D or DexMerc, or something like that which refers to the obsolete names Dexron-III and Mercon. GM isn't licensing that product...they're now recommending Dexron-VI in all Hydramatic transmissions, and TES-389 fluid in Allison transmissions (which IS Dexron-III with a new name). (By the way, Ford is no longer licensing anyone to make Mercon ATF.)
billbrit
Nevada
Posted: 06/07/08 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Thanx, everone. I really appreciate the input.
D & M
Laurel, MD
Posted: 06/07/08 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
I just clipped this from an HWH operators manual found on the HWH website:
"FLUID: HWH Specialty Hydraulic Oil is recommended. In an emergency Dexron automatic transmission fluid can be used.
DO NOT USE brake fluid or hydraulic jack fluid. Use of these can damage seals.
Dexron automatic transmission fluid contains red dye and can cause staining should a leak occur."
Dave & Mary
Isabel (a cuddly little Boston)
Buddy (The Beast) another Boston
2005 Itasca Suncruiser 35A
2003 Jeep Liberty
If it's listed in the Yellow Pages, the government shouldn't be messing around with it.
 > Finding HWH oil
