RV.Net Open Roads Forum: Travel Trailers: rotted trailer tear down pictures and ?'s
 > rotted trailer tear down pictures and ?'s
paedbo
ct
Posted: 06/06/08 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
I had mentioned earlier this week about having rot issues with my trailer. I have been tearing it down and figured id post some pictures of what i have so far. You can clearly see how the front right and front left corners of the trailer are severly rotted. The floor joists are real bad around the water heater. It looks like I'm going to have to remove the skin on the front of the trailer. I know how to get the window out but im alittle uncertain exactly how it comes off. Hopefully someone can tell me if im right. It's a 1986 terry taurus. Do i remove the corner strips to expose the screws then take them out and pull the staples from the bottom of the skin and work my way up?
Here are the pics
86 Terry Taurus rot pictures.
Thanks
Fiverwheel
Southern CA
Posted: 06/06/08 11:14pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, remove the windows then the corner mouldings and then the staples that are underneath. Working from the bottom up will enable you to slip the skin out one section at a time. Be careful to remove all staples and screws. If you want a stronger frame reinstall kiln dried Douglas Fir. Screw and glue it with Gorilla glue. Have a great time with it!
"Blewbyou"
2002 26.5 MB Lazy Daze
JAYCO32BHDSOWNER
WISCONSIN
Posted: 06/07/08 12:27am Link  |  Quote  |  Print  |  Notify Moderator
Had to do the same thing with my 76 coachmen. If you need to replace and of the interior studs, I laid the siding on the ground put together and used the screw holes as a pattern for the walls. I had to replace one of the front corners floor to ceiling. the hardest part was fabracating a corner round for the top corner. I also had to replace the whole wall where the shower/tub was. and had to replace the bracket where the turn signals were. WHATEVER you do DO NOT do what the idiot did to try and fix the front corner. He used expansion foam insulation to insulate the front. All that did was push the siding out off the studs. Also, it wouldnt hurt to install some new insulation. I used the styrofoam type in the front, and reinforced the bottom of the front below to window with some 1x2's due to rocks and stones, and sealed the seams with silicone caulking to keep it dry from the rain/water wash when driving. OH almost forgot, I used the clay type weather stripping/molding underneath the corner strips, or you could use self sealing screws, (the ones with the rubber washer on them, sheet metal screws i think they are called)Just some ideas for you. And dont forget to re-tar the seams in the front when your done on the roof.
GOOD LUCK!!
p.s. Since I upgraded, I now have a decent hunting shack for sale.
2008 JAYCO JAYFLIGHT G2 32BHDS
1997 GMC SUBURBAN SLT 1500 5.7L
paedbo
ct
Posted: 06/07/08 07:04am Link  |  Quote  |  Print  |  Notify Moderator
I only have to go alittle more than halfway up the wall in the front. I dont plan on messing much with the ceiling. I know i should really remove the whole pieces and replace them but i'd rather splice into the good wood and stay as far away from the ceiling as possible. The side studs I am going to cut out the rotted wood and use cripples to replace the bottom portions. I cant see ripping all that out for 1 foot's worth of rot. I will treat the rest of the wood with CPES for insurance.
paedbo
ct
Posted: 06/08/08 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Pictures
More pics, This is what i got done this weekend.
dodge guy
Chicago, western subs.
Posted: 06/09/08 08:31am Link  |  Quote  |  Print  |  Notify Moderator
I know you bought this used so it`s not your fault.
These pics are the reason why maint. is needed on a TT. if the windows were resealed on a regular basis, and any and all seams and marker lites. you would not have been doing this!
Good luck with the rebuild, looks like your making progress.
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
mecreature
Indianapolis, IN
Posted: 06/09/08 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Man that looks like no fun to me...
good luck..
michcruiser60
Michigan Water Wonderland
Posted: 06/09/08 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like you have a very good start on your project. The only thing I can add to your list of do's would be to use the blue foam board you can get at Home Depot or Lowes. I used 3/4" twice thick in the walls. It really does make it cooler and warmer. Not to mention quieter also.
Now is the time to plan on extra 12v lights or 120v outlets. I added a 12v pourch light and one up front by the tanks and batteries. I also add a 2x4 piece in the front side wall, to mount my flag. That gave it the strength I need to hold it without pulling it out of the wall.
Demo work is the most depressing but its all down hill after that.
Good luck and keep us posted on your work.
Mich60
2001 GMC Sierra 2500HD 8.1/Allison 4x4
1964 Ander-ett 16' TT
Please check out my profile...
"The camera always adds 10 lbs. So the trailer's not over weight."
Stefan
Calgary, Alberta, Canada
Posted: 06/09/08 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
search out 'bobsyouruncle' user name on this site. His rebuild photos and info are awesome, and he has the link in his signature!
Stefan
2003 Chevy Silverado 1500HD, 3.73, 4x4, Crew Cab, 6.0L (loving it!)
2003 Layton lite 232 BH
ccjmt4
Arkansas
Posted: 06/10/08 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I feel for you. I did the same thing two years ago. Never again!!!!
