T bone
Top O Texas
I just got a Franks autoformer.Any suggestions on how to set it up.I plan to install in rear bay and sorta hard wire it.
1999 Georgetown 325S,V-10 Ford.
2002 Ford Ranger Edge toad
carrying a 2001 Yamaha Warrior.
2oldman
WA
maybe these posts have something
Or search in Tech issues.
kix
Racy Point, Florida USA
I can tell you how mine is set up. From the park pedestal through the power cord iknto the autoformer then into the coach. I would suggest that you use plugs (30m or 50 amp....whichever your autoformer is). With plugs you can easily disconnect and by pass the autoformer if and when there is a problem with it.
KIX
'02 Winnebago Ultimate Advantage
350hp Cummins ISC
'93 Jeep Rockcrawler
DDinCincy
Cincy, OH
I'll second the plugs! I just put our Frank's unit in a couple weeks ago as well as as Progressive Industries EMC; all have plugs to make replacement and/or bypass easier.
hershey
Albuquerque,(fulltime) NM, USA
I hardwired mine in before the surge protector. My surge protector saved my bacon today for the first time. Park had a very low voltage situation and autoformer couldn't boost it enough to prevent the surge protectors low voltage cutoff to kickin.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
Wherever I happen to park
You can use a HUGHES install kit.. this kint consists of an outlet and a plug and a pigtail or two.. Basically here is what I did, NOTE that you may have to modify this a bit depending on where you park it.
I opened up my Auto-Transfer switch, removed the SHORE power lines, routed themto an outlet. (RV-50 type) installed a short Male Pigtail in their place (2 or 3 feet)
The pigtail plugs into the auto-former, which plugs into the outlet and.. It works
Maanpa
Central Point, Oregon
Where the 50 AMP cord goes into the electrical unit in basement bay I cut the shore powered cord leaving 2 feet still connect to electrical box. Installed 50 AMP male on to the 2 foot piece and installed a 50 AMP female on the longer shore piece. This way the Hughes Autoformer is secure in the basement away from sticky fingers. Also installed a thermostat fan in the bay to keep from overheating.
Koran & Darlene
Creole , Cajun & Bayou (Our 4 Legged Kids)
2007 Itasca Suncruise 38T
PressurePro/Progressive SP
Steer Safe/Vantage BB/Stowmaster
Hughes Autoformer
2004 Rubicon
Goodsam/PA/F394282
james0930
Ohio
Maanpa,
Can you give more detail on the fan install. I just ordered a Power Master that I want to keep in the compartment (locked) but have been concerned about the heat.
Thanks
Maanpa
Maanpa,
Thanks
--------------------------------------------------------------------------------Hope this is some help to you Jim
Installed a 4 1/2", 12V , 135cfm pancake fan along with a variable control thermostat. Cut 4 1/2" hole in rear of basement facing to the rear for fan, grill and filter. Have fan blowing onto autoformer and exhaust out a three inch outlet. Have thermostat set to turn on fan at 90 degrees. Works great for me.
T bone
Top O Texas
Thanks all, I now have a firm plan.Also plan to incorporate the fan with a thermal switch.
