pauldub
North of Seattle
It's really difficult to siphon gas out of my '03 Winnebago. It's so difficult that I failed and gave up. If the filler on your's is similar, a locking gas cap really doesn't seem necessary.
rgrcpa
Louisiana
The Stant 11510 doesn't work in my Ford E450. The dados on the tank filler pipe are narrow straight up and down "slots" in the pipe. There are four of these slots. The tank cap has four narrow straight protrusions that slide down into the dado slots in the tank filler pipe. The 11510 has an two L shaped protrusions that slide down into the filler pipe slots. So, I am still without a locking gas cap.
Appreciate the try.
Rick Roberts
Real RV Newbie
2002 Jayco Granite Ridge 32'
Jordan_and_Bev
Greenland, NH, USA
If you use gasoline, don't worry about condensation, most gasoline today is 10 percent alcohol. A lot more than the "dry-gas" we used to put in to correct for water in there. Leave it low, no problem! Jordan
Jordan and Bev Spofford
Greenland, NH
2005 Born Free 26' RSB
1995 Suzuki 4WD Toad
Bubby's RV
CA
I got mine at Ford. I took mine in and they had one that fit. I think it was the Econoline Cap. Even says "Ford" on it.
John, Winnebago Minnie 24V
Dakzuki
Carnation, Wa, USA
PapPappy wrote: T18skyguy wrote: You could just keep minimal fuel in it to cut your losses, then whether they drill or syphon you can keep your loss low.
Yes, and increase the condensation in your tank, and the chances of having huge mechanical repair bills.....I'd rather take the odds of getting ripped off by thieves....
Modern fuel systems are "closed" so they get minimal moisture inside anyway. If you are using gas that has alcohol in it like many of us are, it will take care of any moisture that gets in there.
95 Chinook Premier
Camper Ken
Oregon
You guys who think your gas has alcohol in it might be mistaken. A lot of gas around the country is now "E10" meaning it has 10% ethanol, not alcohol.
Ethanol will actually attract moisture. That's why it's a good idea to keep your tank filled during storage periods. You'll have less air space in the tank that way. Most modern cars and trucks have a tightly sealed fuel system if the gas cap is tightened as recommended.
2007 Winnebago Access 31c
(2006 Ford E450 chassis)
ron.dittmer
Near Chicago
Have you tried siphoning gas from your fuel tank lately? You can't get the siphon tube far enough into the tank where the gas is. Near the end of the filler tube, there is a wall that prevents siphoning as well as back-splashing. While filling the tank, gas runs down the filler tube, hits a metal wall, and then makes it's way through a slot in the tube, into the tank.
At least that is how it is on my cars. I haven't tried it on my RV.
edited 06/30/08 12:59pm by ron.dittmer *
Bought new in June 2007, Phoenix Cruiser-2350
Fits inside our garage.
Dingy towing a red Toyota MR2 Spyder
See The Inside by clicking on "View Profile" and scroll down
Bubby's RV
CA
Camper Ken wrote: You guys who think your gas has alcohol in it might be mistaken. A lot of gas around the country is now "E10" meaning it has 10% ethanol, not alcohol.
I'll let you in on a little secret that I learned in organic chemistry class, ethanol IS alcohol.
ct camper
ct
It is much faster for theives to punch a hole in the tanks. I believe there is an anti rollover valve in the filler tubes that makes it extremely hard to siphon.
Locking gas caps are good, however, if you have a vindictive ex wife or girlfriend
klhutch
Sububan Chicago
Bubby's RV wrote: Camper Ken wrote: You guys who think your gas has alcohol in it might be mistaken. A lot of gas around the country is now "E10" meaning it has 10% ethanol, not alcohol.
Ethanol is not the only alcohol by any means but it is the one you can drink. --In moderation.-- Also, the fact that ethanol attracts moisture is what makes gasoline that contains it less susceptible to condensation problems.
Ken
