RV.Net Open Roads Forum: Travel Trailers: Electric jack????
 > Electric jack????
emsdad
Va
Posted: 06/07/08 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
My TT weighs 3600#'s I am not sure what size the hole is for it. I would like to get a electric power jack for it. What recommendations can you make? Where is a good place o look(ie: Ebay,RV dealer?).
Cliford
Whidbey Island , Washington
Posted: 06/07/08 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
do a search on barker jack
2003 2500 Dodge CD
2000 Damon 27R Hornet
2005 Chev 1/2 ton Silverado,1999 Palomino B-800 Bronco Camper
4aSong
Northwest Arizona
Posted: 06/07/08 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Our trailer weights 3200# empty and 4400# fully loaded, we have an ATWOOD 3500 which has been in use for some years now without any problems. When looking purchase the largest capacity jack your budget will allow should you upgrade your trailer you can move the jack to the new trailer. Best place to look is on Ebay (But sometimes they gouge you on shipping so watch for that) and some independent online dealers which run specials now and again. Barker, Atwood are the most common names you will hear and both are rated very good.
Mike and Nancy
Tundra TRD V8 4WD
Prowler 20' Lite ( The Kramalot Inn )
EU2000i * Prodigy * McKesh * Trek
Jim&Peg
Central Ohio
Posted: 06/07/08 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
One source to check http://www.pplmotorhomes.com/parts/rv-jacks-stabilizers-leveling-1.htm
KC8WX
OH IO
Posted: 06/07/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Had this model for about 3 months now from this dealer.
Atwood 3500
2006 Durango SLT 4.7L, 545RFE, 4.10 Motive Gears with TracLoc 2WD AIRAID Cold Air Intake, PML Deep Tranny Pan, KYB Shocks
2007 Wildwood LE 27RB
Equalizer Hitch
Prodigy Brake Controller
old guy
Oregon (pronounced Or e gun)
Posted: 06/07/08 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
what ever model you get, try to get the largest one you can afford. If you ever get a larger TT you can take this one with you. buy only once. do not throw away the old hand jack. you need to put it back on when you trade up.
CampSight
Posted: 06/08/08 12:02am Link  |  Quote  |  Print  |  Notify Moderator
Mine's an UltraFab 3500. Got it *new* on eBay® and I've been pleased with it. Honestly, any of the three major brands will do the job and they're easy to install.
Since you obviously seek simplicity, also consider getting yourself a cordless drill for the stabilizers.
emsdad
Va
Posted: 06/08/08 05:37am Link  |  Quote  |  Print  |  Notify Moderator
How do I find out the size I need? Are they standard? I see most are either 2" or 2 1/4".
Bucky Badger
Madison, WI
Posted: 06/08/08 05:53am Link  |  Quote  |  Print  |  Notify Moderator
since our tt is pretty heavy I figured it was 2 1/4, which it was, you may want to take off you hand jack and measure the hole. Or get the 2 1'4 and you can ream out the hole to fit.
Fred & Jodie, dogs, Zoey & Bella
2007 Nissan Titan, 5.6L Big tow, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
Member Titantalk.com
Nights camping 08 (43)
Rallies/Gatherings
IL
WI
gaymeadowsman
Montgomery, Alabama
Posted: 06/08/08 07:38am Link  |  Quote  |  Print  |  Notify Moderator
On our Surveyor SV291, the hand jack had a 2" tube but the hole in the tounge is 2 1/4. If you you can look under the tounge, check the gap around the tube, Large gap means you have a 2"inch tube in a 2 1/4 hole, small gap, 2 1/4 tube in a 2 1/4 hole
John
Ted
2007 Surveyor SV291
2006 Chevy Silverado Ext Cab LS
 > Electric jack????
