I'm looking into a CL 4005(double slide) and SLC 39'(bedroom slide) and was wondering if a jeep could fit in either of those? What are some of the larger vehicles that you guys have put in your WW?
I looked at Weekend Warriors a few years back and the rear bed was only 6'4" and my Jeep is 6'7" tall. Also the rear ramp could not hold the weight of my CJ-5 all at once, the ramp is longer than my wheel base.
I went with a horse trailer, better build quality and does double duty.
....I will support and defend the Constitution of the United States against all enemies, foreign or domestic...
Yes... no problem. The ramp is shorter than you wheelbase so the full weight of the Jeep is never on the ramp, just one axle at a time. The limit is the rear bed. Can be set to 78". I just clear the double electric queens with a 4.5" lift and 35" tires aired down to 15psi. The standard tie downs are 5000lb rated and are tied to the frame.
Check my profile for links to photo's...
Feel free to PM with questions or call. 909-767-0069
05 Chevy 3500 LT Crew Cab Dually, 06 WW SLC3905,
03 Jeep Wrangler, 4.5" Rubicon Express coils 1" body lift, 35" tires, 9000 lb winch, rock jock dana 60/detroit/4.88 rear, Dana 60/ Detroit /4.88 front
07 Raptor 700R, 07 Kymco 90 (X3)
